Howdy, don’t know where else to reach out to help for this. I see on twitter that several addons that I use have been updated a couple of times. However when I go the configuration tab to see if there are any updates, I have no notifications. For exammple, my Node-Red addon version is 10.2.0, the github repo shows latest version is 10.3.1. My system spec’s below.
HA Blue, core-2021.12.8, supervisor-2021.12.2, Home Assistant OS 7.1
I browsed through the logs and this is what I could find.
Error from the Supervisor Error Log:
22-01-08 06:16:38 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
22-01-08 06:16:38 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules https://github.com/home-assistant/addons /data/addons/core
stderr: 'Cloning into '/data/addons/core'...
fatal: unable to access 'https://github.com/home-assistant/addons/': Failed to connect to github.com port 443 after 31 ms: Connection refused
22-01-08 06:16:38 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / core
22-01-08 06:16:38 INFO (MainThread) [supervisor.resolution.fixups.store_execute_remove] Remove invalid Store: core
22-01-08 06:16:38 ERROR (MainThread) [supervisor.store.repository] Can't remove built-in repositories!
22-01-08 06:16:38 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
I can open a web browser on my Mac and navigate to the github page above, so it seems accessable.
Is there anything I can try to do to remedy this?
UPDATE: My router is a custom router with pfSense and pfblockerNG DNSBL. Apparently, one of the blocklists is somehow blocking access to github for home-assistant, even though I can open a browser and navigate there freely. I temporarily disabled the pfblockerNG service and restarted home assistant. In doing to the above error went away, but now the following error shows:
22-01-08 07:16:38 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-01-08 07:16:38 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-01-08 07:16:38 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-01-08 07:16:38 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-01-08 07:16:38 INFO (MainThread) [supervisor.resolution.fixups.store_execute_reset] Reset corrupt Store: core
22-01-08 07:16:38 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
22-01-08 07:16:39 INFO (MainThread) [supervisor.resolution.fixups.store_execute_remove] Remove invalid Store: core
22-01-08 07:16:39 ERROR (MainThread) [supervisor.store.repository] Can't remove built-in repositories!
22-01-08 07:16:39 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
When I SSH into the Blue, I can freely ping
ha dns info shows:
host:172.30.23.3
locals:
- dns://192.168.86.1
servers: []
update_availabie: false
version: 2021.06.0
version_latest: 2021.06.0
ha dns logs is blank
I still am not notified there are any addon updates available.
Any ideas?
Thanks!
