Not showing all Template sensors after 2023.6
Hi all,
Quick question, i got this sensors that work fine from 1 to 5 but 6 and 7 shows unavailable.
########### Home Cinema Sensors KODI  ###########
##Movie 1
    sensors:
      kodi_recently_movies_1:
        friendly_name: "Kodi Movie 1 Poster"
        icon_template: mdi:movie-roll
        value_template: >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[2].split('poster": "')[1].split('"},')[0]}}
      kodi_recently_movies_name_1:
        friendly_name: "Kodi Movie 1 name"
        value_template: >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[2].split('"title": "')[1].split('",')[0]}}
      kodi_recently_movies_2:
        friendly_name: "Kodi Movie 2"
        value_template:  >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[3].split('poster": "')[1].split('"},')[0]}}
      kodi_recently_movies_3:
        friendly_name: "Kodi Movie 3"
        value_template:  >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[4].split('poster": "')[1].split('"},')[0]}}
      kodi_recently_movies_4:
        friendly_name: "Kodi Movie 4"
        value_template:  >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[5].split('poster": "')[1].split('"},')[0]}}
      kodi_recently_movies_5:
        friendly_name: "Kodi Movie 5"
        value_template:  >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[6].split('poster": "')[1].split('"},')[0]}}
      kodi_recently_movies_6:
        friendly_name: "Kodi Movie 6"
        value_template:  >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[7].split('poster": "')[1].split('"},')[0]}}
      kodi_recently_movies_7:
        friendly_name: "Kodi Movie 7"
        value_template:  >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[8].split('poster": "')[1].split('"},')[0]}}
the information exist
so why is it limiting me to 5 sensors?
Thank you all
Are there any related errors in Setings → System → Logs?
Yes i do, here:
Logger: homeassistant.helpers.event
Source: core.py:1255
First occurred: 10 June 2023 at 23:01:53 (3 occurrences)
Last logged: 10 June 2023 at 23:01:53
Error while dispatching event for sensor.kodi_recently_added_movies to <Job track state_changed event {'sensor.kodi_recently_added_movies'} HassJobType.Callback <bound method TrackTemplateResultInfo._refresh of <TrackTemplateResultInfo {Template<template=({{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[7].split('poster": "')[1].split('"},')[0]}}) renders=6>: <RenderInfo Template<template=({{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[7].split('poster": "')[1].split('"},')[0]}}) renders=6> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset({'sensor.kodi_recently_added_movies'}) rate_limit=None has_time=False exception=None is_static=False>, Template<template=(mdi:movie-roll) renders=4>: <RenderInfo Template<template=(mdi:movie-roll) renders=4> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset() rate_limit=None has_time=False exception=None is_static=True>}>>>
Error while dispatching event for sensor.kodi_recently_added_movies to <Job track state_changed event {'sensor.kodi_recently_added_movies'} HassJobType.Callback <bound method TrackTemplateResultInfo._refresh of <TrackTemplateResultInfo {Template<template=({{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[8].split('poster": "')[1].split('"},')[0]}}) renders=6>: <RenderInfo Template<template=({{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[8].split('poster": "')[1].split('"},')[0]}}) renders=6> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset({'sensor.kodi_recently_added_movies'}) rate_limit=None has_time=False exception=None is_static=False>, Template<template=(mdi:movie-roll) renders=4>: <RenderInfo Template<template=(mdi:movie-roll) renders=4> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset() rate_limit=None has_time=False exception=None is_static=True>}>>>
Error while dispatching event for sensor.kodi_recently_added_movies to <Job track state_changed event {'sensor.kodi_recently_added_movies'} HassJobType.Callback <bound method TrackTemplateResultInfo._refresh of <TrackTemplateResultInfo {Template<template=({{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[9].split('poster": "')[1].split('"},')[0]}}) renders=6>: <RenderInfo Template<template=({{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[9].split('poster": "')[1].split('"},')[0]}}) renders=6> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset({'sensor.kodi_recently_added_movies'}) rate_limit=None has_time=False exception=None is_static=False>, Template<template=(mdi:movie-roll) renders=4>: <RenderInfo Template<template=(mdi:movie-roll) renders=4> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset() rate_limit=None has_time=False exception=None is_static=True>}>>>
  File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 274, in _async_dispatch_entity_id_event
    hass.async_run_hass_job(job, event)
  File "/usr/src/homeassistant/homeassistant/core.py", line 618, in async_run_hass_job
    hassjob.target(*args)
  File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 1154, in _refresh
    self.hass.async_run_hass_job(self._job, event, updates)
  File "/usr/src/homeassistant/homeassistant/helpers/template_entity.py", line 349, in _handle_results
    self.async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 590, in async_write_ha_state
    self._async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 711, in _async_write_ha_state
    hass.states.async_set(entity_id, state, attr, self.force_update, self._context)
  File "/usr/src/homeassistant/homeassistant/core.py", line 1637, in async_set
    state = State(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1255, in __init__
    raise InvalidStateError(
homeassistant.exceptions.InvalidStateError: Invalid state encountered for entity ID: sensor.kodi_recently_movies_6. State max length is 255 characters.
Logger: homeassistant.helpers.template_entity
Source: helpers/template_entity.py:380
First occurred: 10 June 2023 at 23:01:30 (12 occurrences)
Last logged: 10 June 2023 at 23:01:30
TemplateError('UndefinedError: list object has no element 5') while processing template 'Template<template=({{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[5].split('poster": "')[1].split('"},')[0]}}) renders=4>' for attribute '_attr_native_value' in entity 'sensor.kodi_recently_movies_4'
TemplateError('UndefinedError: list object has no element 6') while processing template 'Template<template=({{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[6].split('poster": "')[1].split('"},')[0]}}) renders=4>' for attribute '_attr_native_value' in entity 'sensor.kodi_recently_movies_5'
TemplateError('UndefinedError: list object has no element 7') while processing template 'Template<template=({{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[7].split('poster": "')[1].split('"},')[0]}}) renders=4>' for attribute '_attr_native_value' in entity 'sensor.kodi_recently_movies_6'
TemplateError('UndefinedError: list object has no element 8') while processing template 'Template<template=({{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[8].split('poster": "')[1].split('"},')[0]}}) renders=4>' for attribute '_attr_native_value' in entity 'sensor.kodi_recently_movies_7'
TemplateError('UndefinedError: list object has no element 9') while processing template 'Template<template=({{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[9].split('poster": "')[1].split('"},')[0]}}) renders=4>' for attribute '_attr_native_value' in entity 'sensor.kodi_recently_movies_8'
Logger: homeassistant.components.recorder.db_schema
Source: components/recorder/db_schema.py:585
Integration: Recorder (documentation, issues)
First occurred: 10 June 2023 at 23:01:40 (6 occurrences)
State attributes for sensor.kms_t_d87b74735fdd15d17806e9506a238efb exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
State attributes for sensor.kms_m_d87b74735fdd15d17806e9506a238efb exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
State attributes for sensor.kodi_recently_added_tv exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
State attributes for sensor.kodi_recently_added_movies exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
It looks like the URL for the poster contains more than 255 characters so the state can’t be displayed or stored.
Is there any way around it?
no. the state is always limited to 255 characters.
you can store longer strings in an entity’s attributes but I don’t know if that will help you.
do you know how i could make it in to a attribute?
like:
json_attributes:
- “url”
in case anyone has the same question, here is the working sensor:
    sensors:
        value_template: 'ok'
        attribute_templates:
          poster: >-
          fanart: >-
