I try to get the right temperature on my screen for a Zwave Floorheating of HeatIt
I see more instances - the temperature sensor readings of sensor.general_thermostat_v2_instance_1_air_temperature and sensor.general_thermostat_v2_external_sensor are ‘0’
the right temperature is on instance 2: sensor.general_thermostat_v2_floor_sensor
How do I get the temperature of sensor.general_thermostat_v2_floor_sensor overwriting sensor.general_thermostat_v2_instance_1_air_temperature or sensor.general_thermostat_v2_external_sensor or can I change something on the template for climate.vloerverwarming_badkamer? Help will be appriciated
See above picture - I like to have the right temperature in the thermostat block
Thank you in advance,
Peter
