Not starting after Restore
Hi there,
I just restored an old complete SD card backup which was running great that time creating it. Now when I boot it Home Assistant is not starting, because the supervisor seems to crash. I can only find this log message:
KeyError: 'CgroupVersion'
22-07-06 11:49:35 ERROR (MainThread) [asyncio] Unclosed client session
client_session: <aiohttp.client.ClientSession object at 0xb3c05c10>
Can anyone explain why this happens? This image runs great a few weeks ago.
Your are probably running a Supervised installation and the Supervisor updated to the latest version automatically.
Do bit of search how to update supervisor manually to 2022.07.0, as it fixes the problem. But generally you should update Docker to 20.10.0.
I have this same issue -
Iā€™m running hassio in a VM -
given the supervisor wont start, how can I manually update it?
ā€˜ha supervisor updateā€™ does not work, as it needs the supervisor to run
Also, how can the docker version itself be updated from hassio?
So the core is still running and you can access it though SSH?
Otherwise what OS are you running? If it is Supervisedā€¦
I can login and access the emergency terminal (as the hassio_cli does not start), but it allows me to access the system. From there I can start the homeassistant docker container so can get the core working - but every time I try start the supervisor I get the Unclosed client session error.
So Iā€™m caught in a loop - cannot start supervisor ā†’ try to update supervisor ā†’ supervisor needs to be runining to run the ā€˜ha supervisor updateā€™ command.
So is there something I can do to get out of this ?
Have a look on the observer what it says, why the supervisor fails:
If it is the same issue with 2022.06.3 as described in the linked Github issues above, then from the terminal run this to list the running containers:
docker ps
Then you can do a:
docker pull homeassistant/XXXXX-hassio-supervisor:2022.07.0 or docker pull homeassistant/XXXXX-hassio-supervisor:latest where XXXXX is the architecture what you are using. (Probably the second one is the right choice.)
And then a
docker tag homeassistant/XXXXX-hassio-supervisor:latest homeassistant/XXXXX-hassio-supervisor:latest
Edit: I updated to the correct ones, I typed from memory beforeā€¦
The observer simply says the supervisor is not connected - but that is no surprise, the supervisor does not start - with the exact same error as the OP.
I tried the command you gave as:
docker pull homeassistant/amd64-hassio-supervisor:2022.07.0
it now gives me a file now found error:
screenshot
When I run this container, do I need to give it commands to specify -v paths and network addresses, etc?
Note: I tried the docker images command and it listed a version of the supervisor loaded from 9 days ago - I was out of the country then, so I assume this was the version that broke everything:
docker images
If you really have the same issue, then look here:
When starting up the host, it should start the latest version of the supervisor along the core and everything.
Whoop! that did it, thanks a million!
Thanks to OP for starting the thread and thanks to @GSzabados for the commands needed.
