I just upgraded my environment to Stretch in order to get the latest version of HA up and running.
So far, HA is starting up and everything seems to work.
However, I have now issues with Appdaemon, not starting despite the fact that it was working fine on the older version.
The system log gives me the following error
/usr/local/bin $ appdaemon -help -D
File “/usr/local/bin/appdaemon”, line 7, in
from appdaemon.admain import main
ImportError: No module named ‘appdaemon’
In order to fix it, I tried to reinstall Appdaemon, but that also runs into issues. Do you have any idea what the solution could be ?
sudo pip3 install appdaemon
Collecting appdaemon
Using cached appdaemon-2.1.12-py3-none-any.whl
Requirement already satisfied: astral in /usr/local/lib/python3.5/dist-packages (from appdaemon)
Collecting iso8601 (from appdaemon)
Exception:
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 594, in urlopen
chunked=chunked)
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 391, in _make_request
six.raise_from(e, None)
File “”, line 2, in raise_from
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 387, in _make_request
httplib_response = conn.getresponse()
File “/usr/lib/python3.5/http/client.py”, line 1198, in getresponse
response.begin()
File “/usr/lib/python3.5/http/client.py”, line 297, in begin
version, status, reason = self._read_status()
File “/usr/lib/python3.5/http/client.py”, line 266, in _read_status
raise RemoteDisconnected(“Remote end closed connection without”
http.client.RemoteDisconnected: Remote end closed connection without responseDuring handling of the above exception, another exception occurred:
File “/usr/lib/python3/dist-packages/pip/basecommand.py”, line 215, in main
status = self.run(options, args)
File “/usr/lib/python3/dist-packages/pip/commands/install.py”, line 353, in run
wb.build(autobuilding=True)
File “/usr/lib/python3/dist-packages/pip/wheel.py”, line 749, in build
self.requirement_set.prepare_files(self.finder)
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 554, in _prepare_file
require_hashes
File “/usr/lib/python3/dist-packages/pip/req/req_install.py”, line 278, in populate_link
self.link = finder.find_requirement(self, upgrade)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 465, in find_requirement
all_candidates = self.find_all_candidates(req.name)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 423, in find_all_candidates
for page in self._get_pages(url_locations, project_name):
File “/usr/lib/python3/dist-packages/pip/index.py”, line 568, in _get_pages
page = self._get_page(location)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 683, in _get_page
return HTMLPage.get_page(link, session=self.session)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 792, in get_page
“Cache-Control”: “max-age=600”,
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 501, in get
return self.request(‘GET’, url, **kwargs)
File “/usr/lib/python3/dist-packages/pip/download.py”, line 386, in request
return super(PipSession, self).request(method, url, *args, **kwargs)
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 488, in request
resp = self.send(prep, **send_kwargs)
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 609, in send
r = adapter.send(request, **kwargs)
File “/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py”, line 47, in send
resp = super(CacheControlAdapter, self).send(request, **kw)
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py”, line 423, in send
timeout=timeout
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 643, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/retry.py”, line 315, in increment
total -= 1
TypeError: unsupported operand type(s) for -=: ‘Retry’ and ‘int’
