Hi All,
Hoping you can help me
I’m using Sparkydave’s Garden Irrigation Package with a few (Read Lots) of modifications…
Its generating the following in the logs :-
2019-02-01 19:41:26 WARNING (MainThread) [homeassistant.components.sensor.template] Template sensor retic_program1_watering_day has no entity ids configured to track nor were we able to extract the entities to track from the value template(s). This entity will only be able to be updated manually.
2019-02-01 19:41:26 WARNING (MainThread) [homeassistant.components.sensor.template] Template sensor retic_program2_watering_day has no entity ids configured to track nor were we able to extract the entities to track from the value template(s). This entity will only be able to be updated manually.
The pertinent bit of the Package is :
- platform: template # determine if today is selected as a watering day for program 1
sensors:
retic_program1_watering_day:
value_template: >
{% set sensor_names = [ 'monday', 'tuesday', 'wednesday','thursday','friday','saturday','sunday'] %}
{% set today_name = sensor_names[now().weekday()] %}
{% set entity_id = 'input_boolean.retic_program1_'+today_name %}
{{ is_state(entity_id, 'on') }}
retic_program2_watering_day:
value_template: >
{% set entity_id = 'input_boolean.retic_program2_'+today_name %}
Looking at this, I’m guessing I need to specify the entity_id as HASS cant automatically work it out. Funnily enough, neither can I.
I also now use some parameters to see if its likely to rain, or if it has already rained, and depending on sliders to adjust ‘acceptable rain’ values, the irrigation will not run that day. But it sounds like you have the rest sorted. Glad to see someone using some of my code
