Not sure why my contact sensor is not turning on my garage light
I have built in four actions to turn on/off my garage light.
  1. During the daytime when the daytime light is below a certain level and the garage door opens the garage light will turn on. (I have included motion sensors also in here, the motion sensors work and turn the garage light on.)
  2. When the garage door opens after sunset and before sunrise the garage light will turn on. (I have included motion sensors also in here, the motion sensors work and turn the garage light on.)
  3. When the house door for the garage door opens and 1. the light is off 2. it is below a certain brightness the garage light will turn on
  4. When no motion is detected for 10 minutes or the brightness is above a certain level the garage light will turn off.
The garage door opening does not work with #1 and #2.
alias: Garage Light On/Off
description: |-
  Garage Motion Sensor Turns Garage Light On/Off
  Garage Door Opens Turns Garage Light On
  - platform: state
    entity_id:
      - binary_sensor.garage_motion_sensor_1_occupancy
    to: "on"
  - platform: state
    entity_id:
      - binary_sensor.garage_motion_sensor_3_occupancy
    to: "off"
    for:
      hours: 0
      minutes: 10
      seconds: 0
  - platform: numeric_state
    entity_id:
      - sensor.garage_motion_sensor_3_illuminance_lux
    above: 100
  - platform: state
    entity_id:
      - binary_sensor.garage_side_door_contact_sensor_contact
    to: "on"
  - platform: state
    entity_id:
      - binary_sensor.garage_door_sensor_1_contact
    to: "on"
  - platform: state
    entity_id:
    to: "on"
  - platform: state
    entity_id:
      - binary_sensor.garage_entryway_contact_door_sensor_contact
    to: "on"
condition: []
  - choose:
      - conditions:
          - condition: trigger
            id:
              - garageENTRYWAYOPEN
          - condition: numeric_state
            entity_id: sensor.garage_motion_sensor_3_illuminance_lux
            below: 100
        sequence:
          - if:
              - condition: state
                entity_id: light.garage_light_switch
                state: "off"
            then:
              - service: light.turn_on
                data: {}
      - conditions:
            id:
              - motionACTIVE
              - GarageOpen
              - garageSIDEDOOROPEN
              - motionACTIVE3
          - condition: time
            after: sensor.sun_next_setting
            before: sensor.sun_next_rising
        sequence:
            data: {}
      - conditions:
            id:
              - motionACTIVE
              - GarageOpen
              - motionACTIVE3
            below: 50
        sequence:
            data: {}
      - conditions:
            id:
              - motionINACTIVE
              - illuminance100
        sequence:
          - service: light.turn_off
            metadata: {}
            data: {}
mode: restart
  "trace": {
    "last_step": "action/0/choose/0/sequence/0/if/condition/0/entity_id/0",
    "run_id": "72f933d53ca056960fec0c6bf57a1484",
    "state": "stopped",
    "script_execution": "finished",
    "timestamp": {
      "start": "2024-05-29T23:12:20.261962+00:00",
      "finish": "2024-05-29T23:12:20.284129+00:00"
    "domain": "automation",
    "item_id": "1711250201299",
    "trigger": "state of binary_sensor.garage_entryway_contact_door_sensor_contact",
    "trace": {
      "trigger/6": [
          "path": "trigger/6",
          "timestamp": "2024-05-29T23:12:20.262539+00:00",
          "changed_variables": {
            "this": {
              "entity_id": "automation.garage_motion_sensor_garage_light_on_off",
              "state": "on",
              "attributes": {
                "id": "1711250201299",
                "last_triggered": "2024-05-29T23:12:15.696455+00:00",
                "mode": "restart",
                "current": 0,
                "friendly_name": "Garage Light On/Off"
              "last_changed": "2024-05-29T12:56:11.764925+00:00",
              "last_updated": "2024-05-29T23:12:15.747146+00:00",
              "context": {
                "id": "01HZ3A09TETRKVQW3ED1038DNV",
                "parent_id": "01HZ3A09T58RZMP7BWP7HMR7RH",
                "user_id": null
            "trigger": {
              "id": "garageENTRYWAYOPEN",
              "idx": "6",
              "alias": null,
              "platform": "state",
              "entity_id": "binary_sensor.garage_entryway_contact_door_sensor_contact",
              "from_state": {
                "state": "off",
                "attributes": {
                  "device_class": "door",
                  "friendly_name": "Garage Entryway Contact Door Sensor Door"
                "last_changed": "2024-05-29T22:27:17.909178+00:00",
                "last_updated": "2024-05-29T22:27:17.909178+00:00",
                "context": {
                  "id": "01HZ37DZ8N1V0M61ZGWYYMYE9S",
                  "parent_id": null,
                  "user_id": null
              "to_state": {
                "state": "on",
                "attributes": {
                "last_changed": "2024-05-29T23:12:20.256491+00:00",
                "last_updated": "2024-05-29T23:12:20.256491+00:00",
                "context": {
                  "id": "01HZ3A0E90DJDSE6XR1GTYZZAR",
                  "parent_id": null,
                  "user_id": null
              "for": null,
              "attribute": null,
              "description": "state of binary_sensor.garage_entryway_contact_door_sensor_contact"
      "action/0": [
          "path": "action/0",
          "timestamp": "2024-05-29T23:12:20.273224+00:00",
            "context": {
              "id": "01HZ3A0E95D70CRYDHE8NFTE5R",
              "parent_id": "01HZ3A0E90DJDSE6XR1GTYZZAR",
              "user_id": null
          "result": {
            "choice": 0
      "action/0/choose/0": [
          "path": "action/0/choose/0",
          "timestamp": "2024-05-29T23:12:20.273903+00:00",
          "result": {
            "result": true
      "action/0/choose/0/conditions/0": [
          "path": "action/0/choose/0/conditions/0",
          "timestamp": "2024-05-29T23:12:20.274142+00:00",
          "result": {
            "result": true
      "action/0/choose/0/conditions/1": [
          "path": "action/0/choose/0/conditions/1",
          "timestamp": "2024-05-29T23:12:20.274383+00:00",
          "result": {
            "result": true
      "action/0/choose/0/conditions/1/entity_id/0": [
          "path": "action/0/choose/0/conditions/1/entity_id/0",
          "timestamp": "2024-05-29T23:12:20.274499+00:00",
          "result": {
            "result": true,
            "state": 37
      "action/0/choose/0/sequence/0": [
          "path": "action/0/choose/0/sequence/0",
          "timestamp": "2024-05-29T23:12:20.280294+00:00"
      "action/0/choose/0/sequence/0/if": [
          "path": "action/0/choose/0/sequence/0/if",
          "timestamp": "2024-05-29T23:12:20.280620+00:00",
          "result": {
            "result": false
      "action/0/choose/0/sequence/0/if/condition/0": [
          "path": "action/0/choose/0/sequence/0/if/condition/0",
          "timestamp": "2024-05-29T23:12:20.280778+00:00",
          "result": {
            "result": false
      "action/0/choose/0/sequence/0/if/condition/0/entity_id/0": [
          "path": "action/0/choose/0/sequence/0/if/condition/0/entity_id/0",
          "timestamp": "2024-05-29T23:12:20.280921+00:00",
          "result": {
            "result": false,
            "state": "on",
            "wanted_state": "off"
    "config": {
      "alias": "Garage Light On/Off",
      "description": "Garage Motion Sensor Turns Garage Light On/Off\nGarage Door Opens Turns Garage Light On",
      "trigger": [
          "entity_id": [
            "binary_sensor.garage_motion_sensor_1_occupancy"
          "to": "on",
          "id": "motionACTIVE"
          "entity_id": [
            "binary_sensor.garage_motion_sensor_3_occupancy"
          "to": "off",
          "id": "motionINACTIVE",
          "for": {
            "hours": 0,
            "minutes": 10,
            "seconds": 0
          "platform": "numeric_state",
          "entity_id": [
            "sensor.garage_motion_sensor_3_illuminance_lux"
          "above": 100,
          "id": "illuminance100"
          "entity_id": [
            "binary_sensor.garage_side_door_contact_sensor_contact"
          "to": "on",
          "id": "garageSIDEDOOROPEN"
          "entity_id": [
            "binary_sensor.garage_door_sensor_1_contact"
          "to": "on",
          "id": "GarageOpen"
          "entity_id": [
          "to": "on",
          "id": "motionACTIVE3"
          "entity_id": [
          "to": "on",
      "condition": [],
      "action": [
          "choose": [
              "conditions": [
                  "condition": "trigger",
                  "id": [
                  "condition": "numeric_state",
                  "entity_id": "sensor.garage_motion_sensor_3_illuminance_lux",
                  "below": 100
              "sequence": [
                  "if": [
                      "condition": "state",
                      "entity_id": "light.garage_light_switch",
                      "state": "off"
                  "then": [
                      "service": "light.turn_on",
                      "target": {
                      "data": {}
              "conditions": [
                  "id": [
                    "motionACTIVE",
                    "GarageOpen",
                    "garageSIDEDOOROPEN",
                    "motionACTIVE3"
                  "condition": "time",
                  "after": "sensor.sun_next_setting",
                  "before": "sensor.sun_next_rising"
              "sequence": [
                  "target": {
                  "data": {}
              "conditions": [
                  "id": [
                    "motionACTIVE",
                    "GarageOpen",
                    "motionACTIVE3"
                  "below": 50
              "sequence": [
                  "target": {
                  "data": {}
              "conditions": [
                  "id": [
                    "motionINACTIVE",
                    "illuminance100"
              "sequence": [
                  "service": "light.turn_off",
                  "metadata": {},
                  "data": {},
                  "target": {
      "mode": "restart"
    "blueprint_inputs": null,
    "context": {
      "user_id": null
  "logbookEntries": [
      "name": "Garage Light On/Off",
      "message": "triggered by state of binary_sensor.garage_entryway_contact_door_sensor_contact",
      "source": "state of binary_sensor.garage_entryway_contact_door_sensor_contact",
      "context_id": "01HZ3A0E95D70CRYDHE8NFTE5R",
      "when": 1717024340.263079,
Your entryway door contact sensor triggered the automation so the first choose action was selected but then the first action in this choose section (an if statement) failed:
          "result": {
            "result": false,
            "state": "on", #### <----- This is...
            "wanted_state": "off" #### <----- what failed
        sequence:
          - if:
              - condition: state
                state: "off"
Your light switch was on but you required it to be off. So no action occurred.
Yes, that is what is supposed to occur.
The contact sensor I have called GarageOpen does not trigger the automation.
GarageOpen does not trigger option 2 or 3. The condition passes when I click test. The motion sensors I have for option 2 and 3 seem to trigger the automation.
Why would you include a completely unrelated trace?
That just wastes everybody’s time.
Does home assistant not download the trace for all 4 actions when you right click and select download?
I clicked on download, opened the json file in notepad and copied everything.
Is this not correct?
It only downloads the currently displayed trace.
But if your sensor is not triggering the automation (as you indicated above) then there will be no trace.
