Hi, my smoke detector can indicate whether the device is tampered. It publishes the “tamper” status, which can be either true or false.
I have set two separate notifications if the tamper is ON and OFF. However, the device sometimes “goes stupid” and the tamper turns on for a second, even though no one is touching the device. Therefore, I set the notification delay to 10 seconds when tampering is ON.
However, I have a problem with setting the notification when the device stops detecting tampering because I cannot set the notification to be sent only if the tampering lasted longer than 10 seconds.
Here is my notification when tmaper is ON:
alias: Tamper start notification
description: ""
- type: tampered
platform: device
device_id: xxx
entity_id: xxx
domain: binary_sensor
for:
hours: 0
minutes: 0
seconds: 10
condition: []
- service: notify.mobile_app_iphone
message: TAMPER
title: Smoke detector
- service: notify.mobile_app_ipad
message: TAMPER
mode: single
This is Notification when tamper goes OFF (It is sent anyway, even if the tamper lasted less than 10 seconds, but it is sent with a 10-second delay).
alias: Tamper end notification
description: ""
- type: not_tampered
platform: device
device_id: xxx
entity_id: xxx
for:
hours: 0
minutes: 0
seconds: 10
condition: []
message: End of tamper
mode: single
I guess the solution is simple, you just have to find it.
Maybe one of you has already set something like this and can help me.
