Hi guys,
Been very busy with work and fixing up my house and general family life that I’ve not touched HA for quite some time.
HassOS 1.11 - Available 4.10
HA Core 0.86.4 - Available 0.111.0
Configurator 2.0 - Available 5.0.0
Duck DNS 1.5 - Available 1.12.0
NodeRed 1.3.0 - Available 6.3.0
And so on!!
Most addons can’t be upgraded now due to OS being so out of date. My question is, what is the easiest, least time consuming, safest etc. way of upgrading to the latest release. I also have broken integrations such as Nest for my smoke alarms and thermostat which i would like to fix in the process.
I suspect you might say backup wipe and start over. If that’s the case, what’s the easiest way of doing that these days and if I’m going to do it, should i install onto something better than a Pi with an SD card. Perhaps something a little better is in order these days.
Looking forward to spending a bit of time on the setup over the next coming weeks and trying to get certain elements working again or working better than they did before.
