Not updating target_temp_high and target_temp_low in climat.generic_thermostat
I’m working on some local side project that updates thermostat based on sensor values using automation. However when automation is triggered target thermostat temperature is updating but target temperature high and low not. I want this feature because it’s part of my university project where I would like to set up temperature ranges for thermostat. I don’t have any physicall thermostat yet, I just testing it on my local machine.
configuration.yaml:
sensor command_sensor:
  - platform: command_line
    command: "cat ~/.homeassistant/temp_sensor1.txt"
    unit_of_measurement: "°C"
sensor command_sensor_2:
    command: "cat ~/.homeassistant/temp_sensor2.txt"
automation:
    platform: state
    entity_id: sensor.command_sensor
    service: climate.set_temperature
    data_template:
      temperature: '{{ states.sensor.command_sensor_2.state }}'
      target_temp_high: '{{ states.sensor.command_sensor_2.state }}'
      target_temp_low: '{{ states.sensor.command_sensor_2.state }}'
climate:
  - platform: generic_thermostat
    heater: switch.study_heater
    operation_mode: auto
    target_sensor: sensor.command_sensor
    target_temperature: 15
log:
17-02-08 07:20:01 INFO (Thread-5) [homeassistant.components.sensor.command_line] Running command: cat ~/.homeassistant/temp_sensor1.txt
17-02-08 07:20:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state sensor.command_sensor=32.4; friendly_name=Command Sensor, unit_of_measurement=°C @ 2017-02-08T07:19:00.828909+01:00>, entity_id=sensor.command_sensor, new_state=<state sensor.command_sensor=33.4; friendly_name=Command Sensor, unit_of_measurement=°C @ 2017-02-08T07:20:01.510726+01:00>>
17-02-08 07:20:01 INFO (Thread-10) [homeassistant.components.sensor.command_line] Running command: cat ~/.homeassistant/temp_sensor2.txt
17-02-08 07:20:01 INFO (MainThread) [homeassistant.components.automation] Executing automation 0
17-02-08 07:20:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event logbook_entry[L]: name=automation 0, entity_id=automation.automation_0, message=has been triggered, domain=automation>
17-02-08 07:20:01 INFO (MainThread) [homeassistant.helpers.script] Script automation 0: Running script
17-02-08 07:20:01 INFO (MainThread) [homeassistant.helpers.script] Script automation 0: Executing step call service
17-02-08 07:20:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service=set_temperature, service_data=temperature=21.5, target_temp_low=21.5, target_temp_high=21.5, service_call_id=140355251837864-1, domain=climate>
17-02-08 07:20:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state climate.study=idle; friendly_name=Study, current_temperature=32.4, operation_mode=idle, temperature=None, min_temp=7, max_temp=35, unit_of_measurement=°C @ 2017-02-08T07:19:00.890309+01:00>, entity_id=climate.study, new_state=<state climate.study=idle; friendly_name=Study, current_temperature=33.4, operation_mode=idle, temperature=None, min_temp=7, max_temp=35, unit_of_measurement=°C @ 2017-02-08T07:19:00.890309+01:00>>
17-02-08 07:20:01 INFO (Thread-6) [homeassistant.components.climate.generic_thermostat] Obtained current and target temperature. Generic thermostat active.
17-02-08 07:20:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state sensor.command_sensor_2=21.5; friendly_name=Command Sensor, unit_of_measurement=°C @ 2017-02-08T07:19:00.830653+01:00>, entity_id=sensor.command_sensor_2, new_state=<state sensor.command_sensor_2=22.5; friendly_name=Command Sensor, unit_of_measurement=°C @ 2017-02-08T07:20:01.532766+01:00>>
17-02-08 07:20:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state climate.study=idle; friendly_name=Study, current_temperature=33.4, operation_mode=idle, temperature=None, min_temp=7, max_temp=35, unit_of_measurement=°C @ 2017-02-08T07:19:00.890309+01:00>, entity_id=climate.study, new_state=<state climate.study=idle; friendly_name=Study, current_temperature=33.4, operation_mode=idle, temperature=21.5, min_temp=7, max_temp=35, unit_of_measurement=°C @ 2017-02-08T07:19:00.890309+01:00>>
17-02-08 07:20:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140355251837864-1>
17-02-08 07:20:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state automation.automation_0=on; friendly_name=automation 0, last_triggered=None @ 2017-02-08T07:19:00.954793+01:00>, entity_id=automation.automation_0, new_state=<state automation.automation_0=on; friendly_name=automation 0, last_triggered=2017-02-08T07:20:01.536878+01:00 @ 2017-02-08T07:19:00.954793+01:00>>
Maybe it’s not possible for generic_thermostat? What could I use instead only for proof of concept to prove that this kind of feature is possible?
AFAIK runtime setting of min_temp and max_temp is not (yet) implemented in generic thermostat: you might want to open an issue about this…
gl
