My Netatmo integration also stopped working, but I don’t have that message.
Actually it seems the webhooks worked on my side. My HA is open on port 443 so maybe that’s the reason.
There’s a warning on the logs about the netatmo camera but it might be normal because I don’t have any, just the thermostat. Also there is an error at the end but I can’t find out if it’s related to netatmo or not.
My relevant log entries:
2021-05-07 11:02:14 INFO (SyncWorker_1) [homeassistant.loader] Loaded climate from homeassistant.components.climate
2021-05-07 11:02:14 INFO (MainThread) [homeassistant.components.light] Setting up light.netatmo
2021-05-07 11:02:14 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.netatmo
2021-05-07 11:02:14 INFO (MainThread) [homeassistant.setup] Setting up climate
2021-05-07 11:02:14 INFO (MainThread) [homeassistant.setup] Setup of domain climate took 0.0 seconds
2021-05-07 11:02:14 INFO (MainThread) [homeassistant.components.climate] Setting up climate.netatmo
2021-05-07 11:02:14 INFO (MainThread) [homeassistant.setup] Setup of domain camera took 0.0 seconds
2021-05-07 11:02:14 INFO (MainThread) [homeassistant.components.camera] Setting up camera.netatmo
2021-05-07 11:02:14 WARNING (MainThread) [homeassistant.components.camera] Platform netatmo not ready yet: None; Retrying in background in 30 seconds
2021-05-07 11:02:17 INFO (MainThread) [homeassistant.components.netatmo] Register Netatmo webhook: [[redacted]]
2021-05-07 11:02:17 INFO (MainThread) [homeassistant.components.netatmo.data_handler] Netatmo webhook successfully registered
2021-05-07 11:02:43 ERROR (MainThread) [aiohttp.server] Unhandled exception
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1152, in _sendfile_fallback
read = await self.run_in_executor(None, file.readinto, view)
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 485, in start
resp, reset = await task
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 440, in _handle_request
reset = await self.finish_response(request, resp, start_time)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 591, in finish_response
await prepare_meth(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_fileresponse.py", line 241, in prepare
return await self._sendfile(request, fobj, offset, count)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_fileresponse.py", line 96, in _sendfile
await loop.sendfile(transport, fobj, offset, count)
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1131, in sendfile
return await self._sendfile_fallback(transport, file,
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1161, in _sendfile_fallback
await proto.restore()
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 263, in restore
self._transport.resume_reading()
File "/usr/local/lib/python3.8/asyncio/sslproto.py", line 344, in resume_reading
self._ssl_protocol._transport.resume_reading()
AttributeError: 'NoneType' object has no attribute 'resume_reading'
