Not working to do snapshot or recording using ESP32 CAM
Hello All. I am here to ask you the function for snapshot or recording using the ESPcam.
I bought the ESpcam mentioned in the link below.
And I think that it is gorgeous to use the camera with a very low price. But I got to know that this Camera dosenot support the snapshot or recording function.
i got the error mesage like below when i tried to do it by following the instruction from the official homeassistant.io site. ( https://www.home-assistant.io/components/stream )
–> Error Message: camera.espcam does not support record service
The reason why i bought this is for the Surveilance by automation and I need to record or get a snapshot to send it to me by telegram or any other ones.
Therefore, Is there anyone who has a solution about this?
THank you in advance.
I had the same concern and wrote a script to make recordings using ffmpeg.
Running the following in a shell session will make a 1 minute recording:
  ffmpeg -i http://ip_of_ha_instance:8123/api/camera_proxy_stream/camera.my_camera?token=YOUR_CAM_TOKEN -t 1 -vcodec copy  /home/videos/recording.mp4
Possibly, you could integrate this with a python script in HA (I am not using the HA frontend and I use Appdaemon for automations). Regarding snapshots, this works fine for me using the built-in snapshot service so you might be doing something wrong when calling the service.
Thank you for your kind explanation. I will try this. Thank you.
Unfortunately, The token is changed from time to time. Therefore, I couldnot input the correct token in the script you mentioned above. How can i input the fixed token?
In addition, I also got this error message, when I input the script you mentioned above.
–> http://192.168.0.xx:8123/api/camera_proxy_stream/camera.my_camera?token=xxxxxxxxxxxxxxxxxxxxxxxxxx invalid data found when processing input
Can you please let us have your additional advice? Thank you in advance.
Did you replace camera.my_camera with the actual name of your camera entity? I am travelling today but I can upload my full python script later that also handles the token that changes every 5 minutes.
sure. I put my own camera name and sorry to make you confused.
It seems that the changed Token is one of the rootcause for no working of the recording. As i checked the token and inputted the your command included with token ASAP before change or I also inputted all command I can do ASAP. But it showed some error message i mentioned above.
Therefore, I think that there is another reason that the recording is not working. But I will try anything i can.
Thank you for your kindness and sorry to disturb your trip. Please let me have your python script later, if available. I appreciate it.
@tjntomas i was wondering if you can post your python script on the forum im also wondering how you did this. :slight_smile:
Sure, I 'll take some time to post the script shortly.
You can get the current access token or most of the required url using templates… assuming the camera’s entity id is camera.esp32_camera
This works for other cameras too; not just esp32 cams :slight_smile:
access token only:
{{ state_attr('camera.esp32_camera','access_token') }}
most of the URL for a single image:
{{ state_attr('camera.esp32_camera','entity_picture') }}
Single image:
https://YOUR_DDNS_URL{{ state_attr('camera.esp32_camera','entity_picture') }}
Video stream:
https://YOUR_DDNS_URL/api/camera_proxy_stream/camera.esp32_camera?token={{ state_attr('camera.esp32_camera','access_token') }}
Thank you for your kind explanation. I can get the snap shot based on your information, But i am still eager to get the solution for recording as well. Thank you.
hello,
i have try your solution but i get an error :
': File exists
/config/shell_scripts/cuisine_camera_shell_script.sh: line 8: syntax error near unexpected token `('
my shell file is :
#!/bin/bash
date
folder=/config/www/cam_record
id=$(date +"%y-%m-%d_%H-%M-%S")cuisine_camera
mkdir $folder
ffmpeg -i https://192.168.1.50:8123/api/camera_proxy_stream/camera.cuisine?token={{ state_attr("camera.cuisine","access_token") }} -t 1 -vcodec copy $folder/$id.mp4
ls -lh $folder/$id.mp4 $folder/cuisine_camera.mp4
cp $folder/$id.mp4 $folder/cuisine_camera.mp4
find $folder -type f -name ‘*.mp4’ -mtime +30 -exec rm {} ;
i am a noob…is someone can help please?
Your script is trying to make a directory that already exists.
hello @nickrout,
thanks for your help, i have solved it 20 minutes ago : https://community.home-assistant.io/t/record-video-from-esp32-cam-config-with-esphome-in-hassio-works-great/153354/16
very happy to record a stream from an esp32cam lol
I am getting this same error. The token and camera name is correct. But was there a solution to overcome this error?
–> http://192.168.0.xx:8123/api/camera_proxy_stream/camera.my_camera?token=xxxxxxxxxxxxxxxxxxxxxxxxxx 2 invalid data found when processing input
Read the post above yours.
