Not works AIO
All in One installer not works:
Exception:
File “/usr/lib/python2.7/dist-packages/pip/basecommand.py”, line 122, in main
status = self.run(options, args)
File “/usr/lib/python2.7/dist-packages/pip/commands/install.py”, line 290, in run
requirement_set.prepare_files(finder, force_root_egg_info=self.bundle, bundl e=self.bundle)
File “/usr/lib/python2.7/dist-packages/pip/req.py”, line 1097, in prepare_file s
req_to_install, self.upgrade)
File “/usr/lib/python2.7/dist-packages/pip/index.py”, line 194, in find_requir ement
page = self._get_page(main_index_url, req)
File “/usr/lib/python2.7/dist-packages/pip/index.py”, line 568, in _get_page
session=self.session,
File “/usr/lib/python2.7/dist-packages/pip/index.py”, line 694, in get_page
req, link, “connection error: %s” % exc, url,
TypeError: str returned non-string (type Error)
Storing debug log for failure in /root/.pip/pip.log
Cleaning up…
Exception:
Downloading/unpacking pycrypto
Cleaning up…
Exception:
File “/usr/lib/python2.7/dist-packages/pip/req.py”, line 1178, in prepare_file s
url = finder.find_requirement(req_to_install, upgrade=self.upgrade)
Downloading/unpacking cryptography
Cleaning up…
Exception:
Downloading/unpacking packaging
Cleaning up…
Exception:
Downloading/unpacking appdirs
Cleaning up…
Exception:
Requirement already satisfied (use --upgrade to upgrade): six in /usr/lib/python 2.7/dist-packages
Cleaning up…
Downloading/unpacking fabric
Cleaning up…
Exception:
fatal: destination path ‘fabric-home-assistant’ already exists and is not an emp ty directory.
hass_rpi_installer.sh: line 139: fab: command not found
What OS were you installing on? Did you follow the instructions in detail (eg, copy and paste each set of commands)?
yes i trying to install on raspbian
Which version of Raspbian? Jessie, or Stretch?
Did you follow this guide,
Jessie, and yes this guide i have follow
Then either:
  • You’ve got a broken install of Jessie (which could be because of a faulty SD card, or a problem with the power supply)
  • You didn’t actually follow the guide
Almost certainly the second, since you shouldn’t be running the install as root, and the log you posted shows you are.
