I have the home assist up and running, the newest version on a 64 bit raspberry pi. The samba works.
But nothing gets discovered.
For a brief moment in time, 1 of my 2 wemo light switches showed up.
But I don’t see the roku, nor the honeywell thermostat. Nor the iRobot Roomba.
I think there may be some router settings that need to be tweaked, but there are umpteen options.
I assigned the Hassio its on static IP address, as I also have done with each of the 2 wemo power switches (each for a lamp). Still they don’t show up.
Wemo switches both work with Alexa, and the app on my phone (using both wifi and cellular connections). Regarding the Wemo, I even made sure all the firmware was updated.
I am using a LAN connection from the raspberry pi to the router.
Any suggestions or thoughts are appreciated.
Here’s my configuration code:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: XX.XXXX (i have the real coordinates in the actual program)
longitude: XX.XXXX
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/Chicago
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
# Secrets are defined in the file secrets.yaml
api_password: XXXXX (I have my real password here)
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
wemo:
media_player:
- platform: roku
climate:
- platform: honeywell
username: [email protected]
password: XXXXX
scan_interval: 600
vacuum:
- platform: roomba
host: 192.168.1.60
password: XXXXX
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
panel_iframe:
configurator:
title: Configurator
icon: mdi:wrench
url: http://192.168.1.197:3218
