- id: daily_weather_forecast
- platform: time
at: '06:30:00'
service: notify.ios_iphone_cezex <-- this thing works
title: 'test'
message: 'test'
- id: at_home_cezex
condition:
condition: state
entity_id: input_boolean.at_home_cezex
state: 'off'
- platform: zone
entity_id: device_tracker.iphone_cezex
zone: zone.home
event: enter
- platform: state
entity_id: device_tracker.ping_iphone_cezex
to: home
for:
minutes: 15
- service: homeassistant.turn_on <-- this thing works
entity_id: input_boolean.at_home_cezary
- service: notify.ios_iphone_cezex <-- this thing doesn't
message: 'test'
I get a message from daily_weather_forecast action, but I don’t get one from at_home_cezex, even if first action homeassistant.turn_on works (the input_boolean.at_home_cezary is being updated properly). Any ideas why?
What if you reverse your two actions…maybe turning the input_boolean to on, then somehow sabotages the second action to send the notification. So try sending the notification first, then using the action to turn off the input_boolean.
I think the problem lies not in configuration, but rather in unreliable push notifications sent to iOS application. I have three input_booleans defined for three people. Yesterday evening and today morning two of them started to work, one did not (and I didn’t change anything). So I’ve decided to modify the config once more and define automation which reacts on input_boolean state change (that way I can verify that all automations work).
At the beginning it didn’t work at all. I’ve restarted the HASS iOS app and now I get the notifications. I suppose it will stop working at some point. Maybe I should switch to other service like Prowl or Pushbullet.
Did you update your push notifications under the Settings>Push Notifications? I believe you may have to do this each time you add one. But even so, it helps to update them manually every once in awhile I find.
