Looking for some advice, I have set up an automation to use Google AI to send a description of what’s happening within an image from CCTV when the is motion.
This description is sent via a Notification to my phone, however once it’s been opened the is no records of this information.
Is the away to see a Notification History within HA or keep a log somehow of them maybe for a week or so
It would be useful to be able to search for an event like man in a red shirt or something like that. To find a specific event.
I solved this by setting up the Signal integration to send myself messages. As these come in a chat, I can scroll up and see history. I can also set Signal to remove the messages some time after I read them. You might be able to do something similar with other messaging services as well.
I used an input_text helper to store my output. Obviously only works if it’s short enough (which in my case it usually is). Could also do something similar but have it utilize the attributes, as that doesn’t have the same character limit.
