I have a Nest thermostat integrated into HA and I’m trying to write something that will warn me if the Nest is calling for heat but the temperature isn’t rising.
Use case: church heating had tripped out this morning. The call for heat from the thermostat had been on since 5am but no temp increase.
You could do something like this. I’ve made up the entity ids as you did not tell us what they were. So you will have to change them.
- platform: state
entity_id: climate.church_nest
to: heat
for:
seconds: 0 # change this to the time it takes to heat the church
minutes: 0
hours: 1
condition:
- condition: template
value_template: >
{{ states('sensor.church_temperature')|float(0) + 5 > state_attr('climate.church_nest','temperature')|float(0) }}
- service: notify.someones_mobile
message: >
The church climate heating is active but the temperature is not within 5°C after an hour.
Set point: {{ state_attr('climate.church_nest','temperature') }} °C
Actual Temperature: {{ states('sensor.church_temperature') }} °C
This waits however long it normally takes the church to heat up after the climate heating is turned on then checks if the actual temperature is within 5° of the set point. If not it notifies someone.
