Notification message getting cutoff
I found this blueprint from the recent newsletter sent out by Home Assistant: https://www.home-assistant.io/blueprints/blog/2023-07/notify_agent_agenda.yaml. I’ve set it up and it is working, however the notification I get on my phone is always cut off at the end. It seems like it is hitting some kind of character limit or something. I made sure to increase the OpenAI tokens from 150 default and have it at 500 currently. Nothing in between seems to affect the result, so it must be something else. I don’t really know where to look, any thoughts?
I have the same issue, it would be great if you can click the notification and then go to the full text.
Is your issue with this blueprint or just with a notification message in general?
i have never tried any other long notifications, so not sure at this moment.
