Notification of update
When everything is settled, my main eyes on HA will be a tablet… so I won’t have a side menu to notify me when there is an update available.
I’d like to create a card that tells me when there is an update available.
I’ve been reviewing some code, but it was from 2019 so quite old. And they were complaining about a built-in update entity going absent after it was triggered.
At the moment, I’ve created myself an input.boolean and used that to create a card on the dash… and I’ve got an automation running that checks all the “update” options for all the entities (including one plug, one light, etc.) and then set that card to true if any of them fires… but honestly, it’s a hack of a way of doing things and I was wondering whether there is any better way please.
alias: Update available
description: ""
triggers:
  - trigger: state
    entity_id:
      - update.advanced_ssh_web_terminal_update
      - update.digital_clock_update
      - update.electric_blanket
      - update.esphome_device_compiler_update
      - update.file_editor_update
      - update.get_hacs_update
      - update.hacs_update
      - update.home_assistant_core_update
      - update.home_assistant_operating_system_update
      - update.home_assistant_supervisor_update
      - update.landing
      - update.mosquitto_broker_update
      - update.music_assistant_server_update
      - update.office_presence
      - update.openwakeword_update
      - update.piper_update
      - update.snowboy_update
      - update.tablet_power
      - update.whisper_update
      - input_boolean.notify_update
    to: "on"
conditions: []
actions:
  - if:
      - condition: trigger
        id:
          - update_present
    then:
      - action: input_boolean.turn_on
          entity_id: input_boolean.notify_update
        data: {}
    else:
      - action: input_boolean.turn_off
        data: {}
mode: single
As it turns out, this code doesn’t work anyway. Just saw an update come through for Whisper and my automation didn’t fire. I need some conditions in my trigger, but what I’m reading isn’t making much sense as the documentation is snippets of code so I can’t see how things fit.
Ok - I’ve got this working… but here’s the thing… after the update has been applied… (a core update ran) … it doesn’t seem to run again in order to reset the input boolean. If I run it manually, then it works…but it doesn’t seem to re-run itself after the core update has applied and HA has restarted.
Grateful for thoughts please.
description: ""
triggers:
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
  - trigger: state
    entity_id:
      - update.soldering_iron
    to: "on"
  - trigger: state
    entity_id:
      - update.office_light
    to: "on"
  - trigger: state
    entity_id:
      - update.landing_light
    to: "on"
  - trigger: state
    entity_id:
    to: "on"
conditions: []
actions:
  - if:
        id:
          - update_present
    then:
        data: {}
    else:
        data: {}
mode: single
I hopefully sorted this by adding a time trigger to the top. It will run every ten minutes and hopefully that should sort things. However, I am concerned that because the initial trigger is a change in update state… that a second trigger won’t capture that state and the condition will clear itself… so I might need to re-write it again to "to: “on” from: any state. Time will tell.
  - trigger: time_pattern
    minutes: "10"
