Notification on HA app with image (different filenames) with NodeRed
Hello guys,
I’m trying to notify my phone when the door ring with the snap of the camera.
I made a flow, but the image sent to my phone appears to be saved on cache and it wasn’t the last that was created.
So I modified the flow, and include the File Access and File Delete nodes, to verify if the snap was created before send the notification and after that, delete the snap, but it didn’t solve my problem
Now I included a counter to change the file name of the snap, but now, the notification is coming with no images.
Can you help me?
[{"id":"da9a461e2c75968c","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"7ac03e9b868b597a","type":"api-call-service","z":"da9a461e2c75968c","name":"","server":"574882af.002ebc","version":5,"debugenabled":false,"domain":"camera","service":"snapshot","areaId":[],"deviceId":[],"entityId":["camera.rua_esq"],"data":"{\"filename\": filename}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":410,"y":180,"wires":[["b9c47819c37dbee1"]]},{"id":"3f8c38fcf378d71d","type":"api-call-service","z":"da9a461e2c75968c","name":"Notify","server":"a86c4410.e2a568","version":5,"debugenabled":true,"domain":"notify","service":"mobile_app_pedrao_iphone","areaId":[],"deviceId":[],"entityId":[],"data":"{\t   \"title\":\"Campainha\",\t   \"message\":\"Campainha foi tocada!\",\t   \"data\":{\t       \"image\": msg.filename,\t       \"priority\":\"high\",\t       \"channel\":\"Doorbell\"\t           }\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":970,"y":180,"wires":[[]]},{"id":"b9c47819c37dbee1","type":"fs-ops-access","z":"da9a461e2c75968c","name":"","path":"path","pathType":"msg","filename":"file","filenameType":"msg","read":true,"write":true,"throwerror":true,"x":630,"y":180,"wires":[["e3546535493a0c63"],["e7235d121839b19e"]]},{"id":"9af32bfbfec0fcba","type":"fs-ops-delete","z":"da9a461e2c75968c","name":"","path":"path","pathType":"msg","filename":"file","filenameType":"msg","x":1310,"y":180,"wires":[[]]},{"id":"78240ffb3a18de63","type":"delay","z":"da9a461e2c75968c","name":"","pauseType":"delay","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1140,"y":180,"wires":[["9af32bfbfec0fcba"]]},{"id":"55d626dfaffdc3a4","type":"counter","z":"da9a461e2c75968c","name":"","init":"0","step":"1","lower":"","upper":"","mode":"increment","outputs":"1","x":280,"y":80,"wires":[["9b0c1198994540e2"]]},{"id":"9b0c1198994540e2","type":"function","z":"da9a461e2c75968c","name":"Create file name","func":"msg.path = \"/config/www/imgs/cameras/\"\nmsg.file = \"rua_esq\" + msg.count +\".jpg\"\nmsg.filename = msg.path + msg.file\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":440,"y":80,"wires":[["7ac03e9b868b597a"]]},{"id":"e3546535493a0c63","type":"delay","z":"da9a461e2c75968c","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":810,"y":180,"wires":[["3f8c38fcf378d71d"]]},{"id":"e7235d121839b19e","type":"delay","z":"da9a461e2c75968c","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":620,"y":280,"wires":[["b9c47819c37dbee1"]]},{"id":"ae8811c08d782ab8","type":"inject","z":"da9a461e2c75968c","name":"","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":80,"wires":[["55d626dfaffdc3a4"]]},{"id":"574882af.002ebc","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true},{"id":"a86c4410.e2a568","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
I just found how to solve this. The problem was on the snap’s path on Notify node.
The solution was create a new line on the function to send the correct path on the message and change the path of snap on Notify node to the path that is created before.
Captura de tela 2023-01-30 141151
Updating my problem.
The problem that I said about the (maybe) cache image still persists.
I attached the screenshot of the notification and you can see that the time of the snapshot is not the time of the notification (that was 9:57).
Question, maybe does the moment of automation make the snapshot, the camera image is not updated?
Can you share the full code please :slight_smile:
My bad… I changed the flow, to try to “pre-update” the snap, and then save the snap that will be sent to the notification. But the problem persists, I really don’t know what to do.
[{"id":"da9a461e2c75968c","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"7ec873503ad50acd","type":"api-call-service","z":"da9a461e2c75968c","name":"","server":"574882af.002ebc","version":5,"debugenabled":false,"domain":"camera","service":"snapshot","areaId":[],"deviceId":[],"entityId":["camera.rua_esq"],"data":"{\"filename\": filename}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":670,"y":160,"wires":[["6f84ab8284b31416"]]},{"id":"9990c38473ca22b6","type":"inject","z":"da9a461e2c75968c","name":"","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":60,"wires":[["2d5a845bc8e48455"]]},{"id":"24dc8031da8b31bd","type":"api-call-service","z":"da9a461e2c75968c","name":"Notify","server":"a86c4410.e2a568","version":5,"debugenabled":false,"domain":"notify","service":"mobile_app_pedrao_iphone","areaId":[],"deviceId":[],"entityId":[],"data":"{\t   \"title\":\"Campainha\",\t   \"message\":\"Campainha foi tocada!\",\t   \"data\":{\t       \"image\": msg.filename_notif,\t       \"priority\":\"high\",\t       \"channel\":\"Doorbell\"\t           }\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1110,"y":160,"wires":[["5f31752159fa5adf"]]},{"id":"6f84ab8284b31416","type":"fs-ops-access","z":"da9a461e2c75968c","name":"","path":"path","pathType":"msg","filename":"file","filenameType":"msg","read":true,"write":true,"throwerror":true,"x":930,"y":160,"wires":[["24dc8031da8b31bd"],["149575740c0e4ca7"]]},{"id":"149575740c0e4ca7","type":"delay","z":"da9a461e2c75968c","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":920,"y":220,"wires":[["6f84ab8284b31416"]]},{"id":"3f8bcb5e30c58abb","type":"fs-ops-delete","z":"da9a461e2c75968c","name":"","path":"path","pathType":"msg","filename":"file","filenameType":"msg","x":1450,"y":140,"wires":[[]]},{"id":"5f31752159fa5adf","type":"delay","z":"da9a461e2c75968c","name":"","pauseType":"delay","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1280,"y":140,"wires":[["3f8bcb5e30c58abb"]]},{"id":"67e821b4c8bbc27e","type":"counter","z":"da9a461e2c75968c","name":"","init":"0","step":"1","lower":"","upper":"","mode":"increment","outputs":"1","x":280,"y":160,"wires":[["6811f17a76c12dcf"]]},{"id":"6811f17a76c12dcf","type":"function","z":"da9a461e2c75968c","name":"Create file name","func":"msg.path = \"/config/www/imgs/cameras/\"\nmsg.file = \"rua_esq\" + msg.count + \".jpg\"\nmsg.filename = msg.path + msg.file\nmsg.filename_notif = \"/local/imgs/cameras/\" + msg.file\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":460,"y":160,"wires":[["7ec873503ad50acd"]]},{"id":"2d5a845bc8e48455","type":"api-call-service","z":"da9a461e2c75968c","name":"","server":"574882af.002ebc","version":5,"debugenabled":false,"domain":"camera","service":"snapshot","areaId":[],"deviceId":[],"entityId":["camera.rua_esq"],"data":"{\"filename\": \"/config/www/imgs/cameras/teste.jpg\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":310,"y":60,"wires":[["93a35ab2e1a75bb0","67e821b4c8bbc27e"]]},{"id":"79f4efb822f892cd","type":"fs-ops-delete","z":"da9a461e2c75968c","name":"","path":"/config/www/imgs/cameras/","pathType":"str","filename":"teste.jpg","filenameType":"str","x":670,"y":60,"wires":[[]]},{"id":"93a35ab2e1a75bb0","type":"delay","z":"da9a461e2c75968c","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":500,"y":60,"wires":[["79f4efb822f892cd"]]},{"id":"574882af.002ebc","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true},{"id":"a86c4410.e2a568","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
        "id": "808b21e4896dc6c4",
        "type": "api-current-state",
        "z": "30801c09897c9fed",
        "name": "Main Door Outside Motion  ON ?",
        "server": "f22f6e73.21e16",
        "version": 3,
        "outputs": 2,
        "halt_if": "on",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "entity_id": "binary_sensor.presence_12",
        "state_type": "str",
        "blockInputOverrides": false,
        "outputProperties": [
                "property": "payload",
                "propertyType": "msg",
                "value": "",
                "valueType": "entityState"
                "property": "data",
                "value": "",
                "valueType": "entity"
                "property": "topic",
                "value": "",
                "valueType": "triggerId"
        "for": 0,
        "forType": "num",
        "forUnits": "minutes",
        "override_topic": false,
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "x": 1810,
        "y": 100,
        "wires": [
                "e1309bb003cd89eb",
                "587c2d584de4b2b1"
        "id": "587c2d584de4b2b1",
        "type": "api-call-service",
        "name": "",
        "version": 5,
        "debugenabled": false,
        "domain": "camera",
        "service": "snapshot",
        "areaId": [],
        "deviceId": [],
        "entityId": [
            "camera.blueiris_exit_home_200"
        "data": "{\"filename\":\"/config/www/camera/exit_home_200.jpg\"}",
        "dataType": "json",
        "mergeContext": "",
        "mustacheAltTags": false,
        "outputProperties": [],
        "queue": "none",
        "x": 2220,
        "y": 140,
        "wires": [
                "99db6b490c31b3bd"
        "id": "99db6b490c31b3bd",
        "type": "delay",
        "name": "",
        "pauseType": "delay",
        "timeout": "15",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 2460,
        "y": 140,
        "wires": [
                "c4e4ca9b25594e2b"
        "id": "c4e4ca9b25594e2b",
        "name": "",
        "server": "",
        "version": 5,
        "domain": "telegram_bot",
        "service": "send_photo",
        "areaId": [],
        "deviceId": [],
        "entityId": [],
        "data": "{\"file\":\"/config/www/camera/exit_home_200.jpg\"}",
        "dataType": "json",
        "mergeContext": "",
        "queue": "none",
        "x": 2690,
        "y": 140,
        "wires": [
        "id": "4876a30cd660d6de",
        "name": "sensor.someone_home ?",
        "version": 3,
        "outputs": 2,
        "halt_if": "True",
        "entity_id": "sensor.someone_home",
                "value": "",
                "property": "data",
                "value": "",
        "for": 0,
        "forType": "num",
        "x": 1530,
        "y": 100,
        "wires": [
                "808b21e4896dc6c4"
        "id": "e1309bb003cd89eb",
        "name": "",
        "version": 5,
        "domain": "camera",
        "service": "record",
        "areaId": [],
        "deviceId": [],
        "entityId": [
        "data": "{\"filename\":\"/config/www/camera/blueiris_exit_home_200.mp4\"}",
        "dataType": "json",
        "mergeContext": "",
        "queue": "none",
        "x": 2250,
        "y": 200,
        "wires": [
                "37a2ccecbdcc0b07"
        "id": "37a2ccecbdcc0b07",
        "type": "delay",
        "name": "",
        "timeout": "40",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 2460,
        "y": 200,
        "wires": [
                "3ee55774aab9cd1f"
        "id": "3ee55774aab9cd1f",
        "name": "",
        "server": "",
        "version": 5,
        "service": "send_video",
        "areaId": [],
        "deviceId": [],
        "entityId": [],
        "data": "{\"file\":\"/config/www/camera/blueiris_exit_home_200.mp4\"}",
        "dataType": "json",
        "mergeContext": "",
        "queue": "none",
        "x": 2710,
        "y": 200,
        "wires": [
        "id": "492c803a84d6694a",
        "type": "server-state-changed",
        "name": "Home Is Away ?",
        "version": 4,
        "exposeToHomeAssistant": false,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "input_boolean.house_away",
        "entityidfiltertype": "exact",
        "outputinitially": false,
        "haltifstate": "on",
        "outputs": 2,
        "output_only_on_state_change": true,
        "for": 0,
        "forType": "num",
        "ignorePrevStateNull": false,
        "ignorePrevStateUnknown": false,
        "ignorePrevStateUnavailable": false,
        "ignoreCurrentStateUnknown": false,
        "ignoreCurrentStateUnavailable": false,
                "value": "",
                "property": "data",
                "value": "",
                "valueType": "eventData"
                "value": "",
        "x": 1240,
        "y": 100,
        "wires": [
                "4876a30cd660d6de"
        "id": "f22f6e73.21e16",
        "type": "server",
        "name": "yuval_Home Assistant",
        "version": 4,
        "addon": false,
        "rejectUnauthorizedCerts": true,
        "ha_boolean": "y|yes|true|on|home|open",
        "connectionDelay": true,
        "cacheJson": true,
        "heartbeat": false,
        "heartbeatInterval": "30",
can you try it
This flow is to send the snap to telegram, so I will need to configure a bot to make it work. I will try and let you know when I do it… Thanks!
I just analyze the snaps created, and I saw when the snaps were created, the image of the camera is not updates, so that’s why it is sending a “wrong” and past snap.
In the image below, you can see that snap was created at 15:07 and camera hour is 12:04.
Does anyone know how can I force an update?
PS: I use RTSPtoWeb - WebRTC for my cameras.
Captura de tela 2023-02-08 210012
