When for exampel i have a alarm that triggers, water sensor activates, fire alarm go on, i would like a notification on my android phone that continuously ring the phone, blink etc until i dismiss the notification.
To be sure i have noticed the alarm.
And it shouldnt matter if phone is in DND mode.
Iam sure someone have done something similiar and can share how it could look like?
have a nice day
There isn’t a super simple way to cover all your criteria…
alias: Repeated Mobile Alarm Alerts
description: ""
mode: parallel
- platform: state
to: 'on'
entity_id: sensor.house_fire
- platform: state
to: 'on'
entity_id: input_boolean.enable_fire_alert
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- conditions:
sequence:
- alias: "Set up variables for the actions"
variables:
action_stop: "{{ 'STOP_' ~ context.id }}"
- repeat:
while:
- condition: state
state: "on"
- condition: template
value_template: "{{ repeat.index <= 30 }}"
sequence:
- alias: "Ask to stop the alerts"
service: notify.mobile_app_<YOUR_PHONE_NOTIFIER>
title: EMERGENCY ALERT
message: "The house is on fire!"
actions:
- action: "{{ action_stop }}"
title: Stop Alerts
channel: alarm_stream
priority: high
- alias: "Wait for a response"
timeout: "00:00:20"
continue_on_timeout: false
wait_for_trigger:
- platform: event
event_type: mobile_app_notification_action
event_data:
- service: input_boolean.turn_off
Ty, i tried your automation but i still only get 1 vibration and no sound like a regular notifikation on my android phone.
I tried some automations yesterday with the alarm_stream setting but no luck.
It should ring the phone right?
Alarm stream will play the whatever sound you have set for your alarm, if you have your alarm sound set to vibrate only, that is what it will do. I believe you should be able to change that by using a volume level command before the repeat:
action…
- service: notify.mobile_app_<your_device_id_here>
message: "command_volume_level"
media_stream: "alarm_stream"
command: 100
Couldnt get it to work but ty for your efforts .
I did a notify alarm in tasker based on the HA notification instead. That turn of dnd mode, max volume and play alarm.mp3 intill stopped.
Some Samsung devices do not respect the Android API here, this was a deliberate change by Samsung. The only workaround for the Android app is too take the phone out of DND send notification then place it back.
