daekka
(Daekka)
April 7, 2019, 6:46pm
1
I have a Nvidia Shield TV. My problem is this I use the notification service as indicated (Notifications for Android TV / Fire TV - Home Assistant ) it works
“message”: “Messagetext”,
“title: “My Notification”,
“data”:{
“file:{
“path”:”/home/homeassistant/.homeassistant/www/doorbell.jpg”
But if I make an automation it doesn’t work.
- service: camera.snapshot
entity_id: camera.mirilla_camara
filename: '/home/homeassistant/.homeassistant/www/doorbell.jpg'
- delay: '00:00:02'
- service: notify.shieldtv
message: "Llaman al timbre...."
title: "Puerta"
file:
path: /home/homeassistant/.homeassistant/www/doorbell.jpg
I have validated the path of the file in the whitelist_external_dirs
Any ideas?
try to wrap the file path in quotes
jparthum
(Jason Parthum)
April 8, 2019, 6:10am
4
Good call @dshokouhi , I overlooked that too.
Correction:
needs to be…
data_template:
title: "Puerta"
file:
path: "/home/homeassistant/.homeassistant/www/doorbell.jpg"
daekka
(Daekka)
April 8, 2019, 4:20pm
5
I don’t know why but this working for me:
> action:
> data:
> - delay: '00:00:02'
> data:
> title: "Puerta"
> data:
> file:
> auth: "digest"
Thank you!
Vennerberg
(Patrik Vennerberg)
April 9, 2019, 2:17pm
6
@daekka
How does your whitelist_external_dirs code looks like in configuration.yaml?
Need some help with mine.
BR
Yoinkz
November 29, 2019, 12:37pm
8
Did you ever get this working?
I assume you are using a NVIDIA Shield that is connected to a TV?
Gilf0y
(Gilf0y)
December 13, 2021, 5:19pm
9
Any idea has this changed w/later updates on 2021/12? I can’t push img from URL to Shield as detailed in nfandroidtv - text (title, mesage) goes well. Anyone having luck w/images through URL to Nvidia Shield yet?
What I have is simple script w/normal notification base. Works; however when I add image (under data) - no dice.
you should really read release notes
