I have a kasa kp115 power monitor plug connected to my washing machine and I am trying to setup notifications to my cell phone for when the washing machine is completed.
I have the plug discovered and setup in HA and have done some monitoring of it to get an idea of when the machine has completed washing clothes. I found out once it is below 3.8 or so watts, it is completed. Problem is, I am not getting notified when the washing machine is done.
My configuration checks out when I validate it and when I do a test push, my phone and IPAD receive the notification via the HA app.
Here is what I see in the logs:
WARNING (MainThread) [homeassistant.components.homeassistant.triggers.numeric_state] Error in ‘Washing Machine ends’ trigger: In ‘numeric_state’ condition: entity sensor.washing_machine_current_consumption state ‘W’ cannot be processed as a number
What can I do to fix this to work? Not sure if I am setting it up right as the plug seems to always pull up to 3.7 watts when not in use. I am new to this and have been trying to figure this out by online searching but I am having no success.
The problem may be strings vs numbers. I set up a separate template binary sensor that converts the consumption to int (you will want to use float for 3.8):
I have a similar one created with automations gui…works fine…the only thing I donot have is the period for the state.
alias: Notify when in use
description: ''
- platform: numeric_state
entity_id: sensor.gosund_2_consumption
above: '45'
condition: []
- service: notify.notify
message: Audio On
title: audio on
mode: single
The error message is indicating the value contains the letter W which is exactly what is present in the unit_of_measurement attribute for a sensor measuring power.
Are you using the Automation Editor to modify the automation?
If you are not, after modifying the automation with a text editor you must execute Configuration > Settings > Server Controls > Reload Automations.
The state value’s type for all entities is a string. At this point in time of Home Assistant’s evolution, only an entity’s attributes can have a value whose type can be something other than string (such as list, integer, float, boolean, etc).
The problem here is that the Numeric State Trigger was instructed to monitor an attribute that merely contains the letter W which (aside from being the wrong thing to monitor) cannot be converted to a numeric value (which is the error message’s complaint).
