Had a hard time searching for this, since the notifications do work correctly when I test, just not when its apart of the automation in node-red.
{“message”:“Home was armed Away at {{now().strftime(’%I:%M%p’)}}”}
If I run that in the services to send a push notification to my phone it comes in correctly.
Home was armed Away at 08:32AM
However once ran in node-red it doesn’t attach the time.
I was using this same method for things like when the garage door opened and closed as well and things were working fine. I’m sure there was a breaking change on one of the last updates I did. I’ll admit I dont always thoroughly read the changes, Love all the work done to HA, been using it for almost 2 years now.
Thank you in advance for any suggestions on what I should look for.
