Notifications comes and goes, very frustrating!
I am a noob at HAAS. I have made a config and made few notifications using iOS which worked then i added more notifications and it stopped working, i thought i did something wrong then i removed the added ones (notifications started to work) then i added the others again and it still worked. At some point in time i did some config changes and notifications stopped working so i thought maybe it’s apple notification service not working i changed to pushbullet which worked but that also stopped when i made changes to HASS. I have no pattern i go after, then changes i made are different and in different places that brakes my notifications.
What’s most weird is that i can test the notifications manually from the HASS web by sending a message manually and that works. I also think the automations work because i can see the state changes in the user interface that should trigger the notification but still it doesn’t work.
It’s very frustrating !
Any ideas would be appreciated.
Without a config posted by you it’s hard to help you. Could you post the part of config that gives your trouble?
~Cheers
