Notifications do not work
I am not sure where to start but I cannot get notifications to work.
I have moved almost everything from my vera to ha but I got stuck on notifications.
I have no clue where to look anymore.
Reinstalled the app, clicked on allow to turn to allowed, rebooted hass, repeated that a dozen times, added notify: mobile_app: and iOS: to y configurationn although it had default_config: already, nothing helps.
How can I debug this thing. Pointers anyone?
There’s no need to set up notification services for the iOS app. The integration will do that for you.
Go to Developer Tools / Services and type notify.mobile_ in the service input text field. What services do you see?
Thanks Tom for your help. The problem was that I did not see any notify.mobile services there at all. After reinstalling my app a few times and hitting the renew button in the settings also a few times, I ended up with multiple sensors for the same iPhone but also at last the so needed notify.mobile_myiphone. So now it works!
There is a procedure documented for cleaning out the mobile integration and starting from a clean slate if you want to remove all those duplicates.
Ignore the title, it can be used for other reasons,
Thanks Tom, I will give that a spin as soon as I have everything moved from my Vera and operational on the HA.
