Notifications Giving Unable To Connect Error, But Everything Seems To Work?
So I just changed my site over to using Cloudflare Proxy and now I am getting the error attached. What is interesting is that everything seems to be fine and work. The error only seems to come up when I get a notification from Frigate via an automation with a video attached. The video even plays, but part way into the video I get this error? Suggestions?
Updates: Tested on iOS and works fine. Trying removing cloudflare and also being internal (so using the internal address), neither fixed it. Also reset the app completely and removed the integration and started over. Same thing.
Click on settings, go to logs and look at the failure as you reproduce the issue. Should give a clue why it’s happening.
Tried that… what’s interesting is I don’t see an error in the logs? It’s ONLY while playing the video from the notification.
Just to double check, I set off the notification. Played the video. Waited for the error. Clicked settings. Then went into the logs and emailed them to myself. I don’t see any error anywhere in there.
Also,
I decided to completely take the proxy out of the equation. It happens when connected locally via the IP directly to the HA instance.
Only thing I can think is I recently changed from ha.sub.domain.com to ha.domain.com… but I changed it in the HA settings and did a full clear on the android app.
This stuff may be an error?
03-20 14:58:44.004 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6586): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:44.920 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6672): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:44.928 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6673): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:44.936 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6674): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:44.944 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6675): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:44.952 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6676): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:46.004 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6724): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:46.044 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6725): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:46.088 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6726): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:46.148 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6727): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:46.204 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6728): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:47.072 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6741): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:47.156 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6742): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:47.204 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6743): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:47.272 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6744): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:47.356 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6745): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:48.088 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6756): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:48.140 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6757): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:48.204 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6758): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:48.276 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6759): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:48.356 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6760): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:49.156 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6772): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:49.209 30728  2778 D BufferPoolAccessor2.0: bufferpool2 0xb400007d453d7d38 : 5(36700160 size) total buffers - 4(29360128 size) used buffers - 90/95 (recycle/alloc) - 5/92 (fetch/transfer)
03-20 14:58:49.208 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6773): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:49.288 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6774): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:49.340 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6775): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:49.424 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6776): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:52.168 30728 31041 D MediaCodec: keep callback message for reclaim
03-20 14:58:52.168 30728  2778 I CCodecConfig: query failed after returning 14 values (BAD_INDEX)
03-20 14:58:52.169 30728  2778 W Codec2Client: query -- param skipped: index = 1073743886.
03-20 14:58:52.169 30728  2778 W Codec2Client: query -- param skipped: index = 1610614798.
03-20 14:58:52.176 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6786): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:52.184 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6787): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:52.192 30728  2785 D CCodecBufferChannel: [c2.exynos.h264.decoder#480] Ignoring stale input buffer done callback: last flush index = 93, frameIndex = 93
03-20 14:58:52.248 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6788): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:52.264 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6789): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:52.268 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6790): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:53.128 30728 30728 D UrlRepository: localUrl is: true and usesInternalSsid is: true
03-20 14:58:53.184 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6893): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:53.200 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6894): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:53.208 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6895): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:53.220 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6896): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:53.228 30728 30728 W Chrome_InProcGp: type=1400 audit(0.0:6897): avc: denied { getattr } for name="/" dev="dmabuf" ino=1 scontext=u:r:untrusted_app:s0:c7,c257,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=filesystem permissive=0 app=io.homeassistant.companion.android
03-20 14:58:53.849 30728 30728 W Choreographer: Frame time is 0.062169 ms in the future!  Check that graphics HAL is generating vsync timestamps using the correct timebase.
Interestingly I posted into the thread for the notification blueprint. I’m not the only one with that issue. So it’s got to be something in the notification using picture/video …
