I am running HA version 0.113.3 and have the following notification:
Invalid config
The following integrations and platforms could not be set up:
-recorder
-history
-logbook
-default_config
Please check your config.
Here is my Configuration.yaml file:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
logger:
sonoff:
username: XXXXXXXXX
password: XXXXXXXXX
input_number:
pump_timer_minutes:
name: "Set Fountain Run Timer"
min: 1
max: 56
step: 5
input_boolean:
pump_timer_enabled:
initial: off
icon: mdi:timelapse
Any ideas what would be causing this notification?
