I started my Home Assistant journey last month. I’m still a beginner, and I apologize in advance for my question, which may seem extremely basic, but despite hours of research and many attempts, it still doesn’t work.
I am not receiving notifications on my iPhone. The app is installed on my phone, all sensors are showing up in Home Assistant, notifications are enabled in both the phone settings and the Home Assistant app, and I can access Home Assistant remotely via Cloudflare… I don’t understand where the problem is.
I also tried creating an automation, but it doesn’t work.
I would like to receive a notification on my iPhone for all Home Assistant alerts (available updates, vacuum blocked, etc.).
Thank you in advance for your help.
Ma configuration
System Information
| version | core-2025.1.4 |
| installation_type | Home Assistant OS |
| dev | false |
| hassio | true |
| docker | true |
| user | root |
| virtualenv | false |
| python_version | 3.13.1 |
| os_name | Linux |
| os_version | 6.6.62-haos-raspi |
| arch | aarch64 |
| timezone | Europe/Paris |
| config_dir | /config |
Home Assistant Community Store
| GitHub API | ok |
| GitHub Content | ok |
| GitHub Web | ok |
| HACS Data | ok |
| GitHub API Calls Remaining | 5000 |
| Installed Version | 2.0.5 |
| Stage | running |
| Available Repositories | 1510 |
| Downloaded Repositories | 14 |
Home Assistant Cloud
| logged_in | false |
| can_reach_cert_server | ok |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
Home Assistant Supervisor
| host_os | Home Assistant OS 14.2 |
| update_channel | stable |
| supervisor_version | supervisor-2024.12.3 |
| agent_version | 1.6.0 |
| docker_version | 27.2.0 |
| disk_total | 28.3 GB |
| disk_used | 7.2 GB |
| healthy | true |
| supported | true |
| host_connectivity | true |
| supervisor_connectivity | true |
| ntp_synchronized | true |
| virtualization | |
| board | rpi5-64 |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | Matter Server (7.0.0), Mosquitto broker (6.5.0), Zigbee2MQTT (2.0.0-2), Advanced SSH & Web Terminal (20.0.0), File editor (5.8.0), AdGuard Home (5.2.3), Cloudflared (5.2.7), Home Assistant Google Drive Backup (0.112.1) |
Dashboards
| dashboards | 4 |
| resources | 9 |
| views | 13 |
| mode | storage |
Recorder
| oldest_recorder_run | 21 janvier 2025 à 11:18 |
| current_recorder_run | 30 janvier 2025 à 12:31 |
| estimated_db_size | 102.88 MiB |
| database_engine | sqlite |
| database_version | 3.47.1 |
