Hello.
I installed home assistant in a VM in proxmox and things went smoothly as I added devices etc. I installed a zigbee dongle and I added some door and window sensors and I added an automation to send me notifications which worked just fine while I was with my iPhone in my local WiFi network. I do not know how but to my surprise it worked even when I was away from home, at least it did for a few days, and then it stopped. Now, I do not even get notifications while I am in the local WiFi on any of my devices. I added 2 different iPhones and an android phone to receive notifications but it still does not work.
Any suggestions as to what I can check or change?
I recently added nabu casa account to see if it would help but it has not. Also, I did use my VPN and in that window when it was working I would get notifications while I had the VPN connected.
Some things to look at could be:
- Are the automations that send the notifications being triggered? Have you checked the traces of the automations to see that the notification actions are being run?
- What if you run these actions manually?
- Are there any related errors in Settings > System > Log?
- If you are using the Companion App, is this working in all other respects?
Just some things to start with…
Hello templeteon_nash,
From what I can tell, yes, the automation is being triggered. I am looking at the automation screen and the door open automation indicates was triggered about an hour ago.
Just now, and a few dozen times over the last 2 weeks, I ran it manually to test and it still do not get the automation alert/notification on my phone.
I did see some errors related to this message:
Logger: frontend.js.latest.202209070 Source: components/system_log/__init__.py:227 First occurred: 9:44:16 AM (1 occurrences) Last logged: 9:44:16 AM :0:0 ResizeObserver loop completed with undelivered notifications.
The companion app works great if I turn on the VPN to my pfsense box and all is great. Notifications is my probem
