Notifications of Replies in this Forum to HA
So, I must be really dense today…and all other days.
Question(s):
a) I don’t see a way to generate notifications for replies in this forum. Am I missing something?
b) Is there a way to integrate message counts or notifications to forum posts in this forum into Home Assistant as a sensor?
I also would love to see a notification/message counter in Home Assistant.
Have you found a solution ?
https://community.home-assistant.io/notifications.json
Should be possible with the REST sensor or something similar.
See https://docs.discourse.org/ for more complete docs
I’ll take a look into that, thanks
Unfortunately, the notification file is accessible only when you’re already logged in. I tried accessing it with curl -u, using my username and password, but it does not support HTTP authentication. Your second link mentions API keys, but I don’t see how to generate it on the forum. I’m not even sure the forum provides an API …
I found this https://meta.discourse.org/t/user-api-keys-specification/48536
It sounds like the ability to get an API key is turned on by default, but there are some hoops you need to go through to generate. Maybe there should be a feature request to create a discourse integration.
I’ll take a chance and request that they provide an option to create API keys for this forum.
I would too be interested in this but getting an API seems hard work…?
For anyone who would still like to know how to receive your replies from this forum into HA, please check out Community Notifications (This forum) Sensor in Home Assistant
