Since version 0.44.x it looks like iOS notification and some other automation is buggy. Sometimes after a complete clean start of Hassbian (first stop HASS, remove the /home/homeassistant.homeassistant/deps/ directory and a reboot it comes back up successfully. After a restart of HASS it usually doesn’t.
I have no errors in the Configuration Validation. I’m using the following code:
automation
- alias: "Startup Notification"
platform: homeassistant
event: start
service: notify.ios_iphonewilfred
message: "Oké! Home Assistant is weer actief!"
- alias: "Bij beweging sensornode2 => sensornode2 led aan"
platform: template
value_template: "{{ states('sensor.bewegingmelder_sn2') == 'Beweging' }}"
service: light.turn_on
entity_id: light.sn2_led
brightness: 100
rgb_color: [0, 0, 255]
- alias: "Bij geen beweging sensornode2 => sensornode2 led uit"
platform: template
value_template: "{{ states('sensor.bewegingmelder_sn2') == 'Rust' }}"
service: light.turn_off
All these three automations doesn’t work if the anomaly occurs. Has anybody have any idea what causes this effect?
