Notifications twitter not working in hass.io
hi,
Moved from hassbian to hass.io which was less painful than I thought it would be. However, I have a few things which don’t work / I don’t understand.
When someone rings the doorbel it is supposed to send a tweet. Working fine in hassbian, but not any longer. The log seems to suggest it triggered the notification. It does not work from the automation script nor from a manual event in the developer section in the web interface.
The log suggests it tried to send a notification;
2017-09-11 21:12:00 INFO (MainThread) [homeassistant.helpers.script] Script DeurBel: Test condition state: True
2017-09-11 21:12:00 INFO (MainThread) [homeassistant.helpers.script] Script DeurBel: Executing step call service
2017-09-11 21:12:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=notify, service=tweet, service_data=title=Opgelet, message=Ik moest kloppen want de bel doet het niet om 21:12:00!, service_call_id=1961142000-159>
It says I had to knock as the doorbel is not working (based on a kids program over here - time stamp added to avoid duplicate tweets which twitter seems to ignore).
I’ve created a new app in twitter and restarted everything but no joy - I have http://127.0.0.1. in all URL fields I could find. Hints more than welcome.
Thanks for reading so far!
Jhh
update:
More testing shows that under hassbian twitter notifications don’t work in 0.53.1 either, downgrade to 0.52.0 and they work again (these are notifications from automations).
Under developer tools, using the “remote” (services) calling a service from a component shows the same result so it looks like it is not the automation which is not working. Notifications to bravia tv work both in version 0.53.0 and 0.52.0
Is there a way to downgrade in hass.io?
