Jsut installed the app and got a test notification to work. After that every time the same auotmation fires there is no notificioat on the deviec and the home-assistant.log shows:
2017-07-22 14:47:07 WARNING (MainThread) [homeassistant.core] Unable to find service notify/ios_chris_iphone
If I reset up the app and change the device name, it works again but only once, then repeats the above.
Try disabling everything in the iOS app, deleting file .ios.conf (should be in the same folder as configuration.yaml), rebooting HASS and then enabling notifications again in the iOS app.
I only have iOS added in my configuration.yaml. Is there another place to check to see what services exist? I am new to HASS so sorry for the dumb question.
So I decided to tear it all to the ground, taking it one step further than @pplucky even suggested.
I took ios out of my config.yaml, deleted .ios.conf and I reset the whole iOS app on my phone. I then reinstalled everything and I know seem to having it working. I even got “Title”, “Subtitle”, and “Message” working. I will see if it keeps working for a while before I declare victory though.
Next up is to try some advanced notificatons. I still have a LONG to-do list to get HA setup so it can replace Smartthings (the app & CoRE as I still intend to use it as a bridge) but making progress.
