Notified when automation is triggered more than 2 days ago
I’ve got the following automation and would like to get notified when the last triggered is more than 2 days ago. is that possible?
{{ state_attr(‘automation.to_the_gym’, ‘last_triggered’) }}
You can create a template based sensor to find the difference of now and last triggered and if it is more than 2 days, trigger the automation.
As a backup (your home assistant might miss the trigger) i could run it on a fixed time everyday with condition of template sensor is greater than 2 days :slight_smile:
I would personally go with the second one only, if it doesn’t have to be just on time.
Make it part of the automation to set a date time helper ti the value of now + 2 days
Then use that helper to trigger the notification.
You can use a Template Trigger.
alias: example
    value_template: "{{ now() - state_attr('automation.to_the_gym', 'last_triggered') > timedelta(days=2) }}"
condition: []
  ...etc...
Would this be triggerred continuously given that delta will be always 2 days, after first trigger.
Assuming that automation_to_gym is a different automation.
To trigger a Template Trigger, it must change state from false to true. Once it’s true, it must return to false before it can trigger again.
