I have to types of notifications: a normal notification and an alert - both come in two flavours: to all people or only people who are at home.
I successfully created a notification system for the normal notification using a script with service_template, see below that takes care of presence.
I have not yet managed to send alerts only to people who are at home. Any ideas?
Here is my code for the normal stuff. At the end of an automation I call
- service: notify_people_who_are_present
title: foo
message: bar
and the script looks like this
notify_people_who_are_present:
alias: Notify people who are present
sequence:
- service_template: >
{% if is_state('person.stefan', 'home') %}
notify.mobile_app_swaiphone
{% else %} {% endif %}
data_template:
title: '{{ title }}'
message: '{{ message }}'
{% if is_state('person.julia', 'home') %}
notify.mobile_app_jphone
data_template:
{% if is_state('person.anna', 'home') %}
notify.mobile_app_iphone_von_anna
data_template:
mode: single
That was fairly easy. How do I create an alert that notifies certain people based on a condition such as presence? I didnāt succeed using service templates
fake_alert:
done_message: fake done
entity_id: sensor.swa_fake
state: 'on' # Optional, 'on' is the default value
repeat:
- 1
can_acknowledge: true # Optional, default is true
# skip_first: true # Optional, false is the default
notifiers:
- urgent_notification
Apparently, one cannot use service templates within notifiers?
Thanks Jason for the hints. Will adapt the code. I think of alerts as āurgentā and/or āimportantā notifications. I like alerts because they reach the phone even if put on silent mode. Plus, I get repeated notifications and a confirmation if the problem is solved. Too bad, one cannot template notifiers in alerts.
That repeat loop is not exactly what I was looking for. It loops regardless if the original problem (why the āalertā was triggered in the first place) still persists.
I could get around it if I define the same trigger with different intervals, say
- platform: state
for: 00:05:00
to: 'on'
entity_id: group.windows
- platform: state
for: 00:10:00
to: 'on'
I have no idea yet how to address the case that the windows got closed in between and I want a notification for that as well (similar to the alert function). I could have a state somewhere but that gets messy and hard to maintain.
That was just an example to show you how to use a loop in a script. I pointed to the docs for script syntax so you could figure out how to change it to what you need.
You needed to change value_template: "{{ repeat.index < 5 }}" to the condition you required to start with. If you were intending on using the same trigger as your alert you would change that to.
Now that automation will continue to repeat until sensor.swa_fake turns off. It will not run at all if swa_fake does not turn on. BTW that delay is important. Without it the script will keep repeating immediately and eventually something will crash.
If you spell out exactly what you want to do for one of your alerts Iāll help you put it together and you can use it as an example to figure out the rest.
Your other choice is to create a separate alert trigger sensor and alert for each event for each person.
Iāve come up with a form (using everyone above as inspiration) that is quite flexible: it can notify individuals at home or anyone at home.
I have one prerequisite: each person has a person entity and a notify service call, each with the same name. So, for instance, I would have person.aaron and notify.aaron.
In that case, the first script notifies a person if they are home (note that I have some fields, like interruption_level and tag that are specific to the iOS companion app):
notify_person_if_at_home:
alias: "Notify Person if at Home"
fields:
interruption_level:
description: The interruption level to set
example: critical
message:
description: The message to send
example: Your hair is on fire!
name:
description: The lowercase name of the person to notify
example: aaron
title:
description: The optional title to include
example: Heads Up
sequence:
- alias: "Is the person at home?"
condition: template
value_template: "{{ states('person.' + name) == 'home' }}"
- alias: "Send the message"
service: "notify.{{ name }}"
message: "{{ message }}"
title: "{{ title }}"
push:
interruption-level: "{{ interruption_level }}"
tag: "{{ message }}"
Then, a second script can use this building block to notify everyone at home:
notify_everyone_at_home:
alias: "Notify Everyone at Home"
fields:
interruption_level:
example: critical
message:
title:
example: Heads Up
sequence:
- alias: "Notify Aaron if he's at home"
service: script.turn_on
entity_id: script.notify_person_if_at_home
interruption_level: "{{ interruption_level }}"
- alias: "Notify Britt if she's at home"
Using some other messages as inspiration - Iāve created a similar script to only notify people based on their location. It relies on having a custom attribute for each person to link people to their notifier.
alias: Notify people based on location
mode: parallel
fields:
TITLE:
description: Notification title
example: "Example Notification"
required: true
MESSAGE:
description: Message of notification
example: "Something is happening"
required: true
description: State of people to send notification to
example: "home"
default: "home"
required: false
DEBUG:
description: Only send messages to T
example: true
default: false
required: false
sequence:
# Determine all the people at scripted location to send notification to
# Have debug handling to only send to me when debug = true
- variables:
NOTIFIERS: >
{% if DEBUG %}
{{ states.person | selectattr("entity_id", "eq", "person.t") | selectattr('state', 'eq', LOCATION) | map(attribute='attributes.notifier') | list }}
{% else %}
{{ states.person | selectattr('state', 'eq', LOCATION) | map(attribute='attributes.notifier') | list }}
{% endif %}
# Iterate through all the people and send the relevant notification
- repeat:
count: "{{ NOTIFIERS | count }}"
sequence:
- variables:
NOTIFIER: "{{ NOTIFIERS[repeat.index - 1] }}"
- service: "{{ NOTIFIER }}"
title: "{{ TITLE }}"
message: "{{ MESSAGE }}"
As shown in Jasonās original script, each person should be their own Choose action so that they are evaluated independently. Your script is currently 1 Choose action for 6 people instead of 6 Choose actions.
Thank you. Thatās what if you just copy & paste different things. Someone on the discord also told me this and I then just redid the whole thing via the ui and it now works perfectly
then you donāt have to create a notify event per user. downside is that now only the source device is listed and not all device_trackers, but if you want that, I think itās easy to implement that as well.
According to the documentation mobile notification always has the same format
