Sometimes you want to send a notification only to the persons that are currently at home. This blueprint allows you to do that quite easily.
This blueprint creates a script which can be used like most notify
services. When you call the script, it checks if the person is at home; if so, the notification is sent.
Configuration
In order to create the script, you need to supply a mapping of person names with their corresponding notify services. Say you’ve got two persons, Lisa and John, resulting in two person
entities: person.lisa
and person.john
. For Lisa, you want to send a notification to notify.lisa
, and for John, you want to send a notification to notify.mobile_app_john
. The mapping will then look like this:
lisa: notify.lisa
john: notify.mobile_app_john
Usage
The blueprint will create a script, e.g. script.notify_everybody_at_home
, which you can supply with a number of parameters. These are documented in the script and shown in the service developer tools.
The following parameters can be specified:
message
: Notification text. -
title
: Notification title. -
data
: Notification data, depends on the platform used to send the notification. -
persons
: List of persons you want to notify, useful if you want to send the notification only to a specific set of people. If not specified, all persons configured in the blueprint are notified.
The message
, title
and data
parameters are passed directly to the configured notify
services.
Limitations
The script calls all the notification services with the same data object (if supplied). It may therefore not work if you are using different notification platforms, e.g. the Android app and Pushbullet. In some cases, you can solve this kind of problems by creating a notify group.
More info on my GitHub: GitHub - crnh/home-assistant-blueprints: Home Assistant Blueprints.
blueprint:
domain: script
name: Notify everybody at home
source_url: https://github.com/crnh/home-assistant-blueprints/blob/7e6aa06193165bb5c01fec197849347c1a1193a2/notify_everybody_at_home.yaml
input:
person_service_map:
name: Person notify services
description: >
Mappings between person names and their corresponding notify services.
The default value shows what the object should look like if the service
`notify.mobile_app_john` belongs to `person.john`.
selector:
object:
default:
mode: parallel
fields:
persons:
description: >
List with persons who should get a notification. If not supplied, all
persons will be used.
required: false
selector:
object:
title:
description: Title of the notification
required: false
selector:
text:
message:
description: Message to send
required: true
selector:
text:
multiline: true
description: Notification data object
required: false
selector:
object:
sequence:
- variables:
person_service_map: !input person_service_map
persons: >
{% set all_persons = person_service_map.keys() | list %}
{{ persons | default(all_persons, true) }}
- repeat:
count: "{{ persons | count }}"
sequence:
- choose:
conditions:
- "{{ is_state('person.' ~ persons[repeat.index - 1], 'home') }}"
sequence:
- service: "{{ person_service_map[persons[repeat.index - 1]] }}"
title: "{{ title | default }}"
message: "{{ message | default }}"
data: "{{ data | default({}) }}"
