<!-- READ THIS FIRST:
- Make sure you run the latest version of the Android app…
- Make sure you run the latest version of Home Assistant
- Make sure to check the Companion docs for troubleshooting and configuration: https://companion.home-assistant.io/
- Make sure the bug you found is not already reported, we love to put work in bugfixes instead of closing duplicate bug reports
DO NOT DELETE ANY TEXT from this template! All requested information is important.
**Home Assistant Android version:** beta-637-94e1f15
**Android version:** 11
**Phone model:** SM-G991U
**Home Assistant version:** 2021.3.4
**Last working Home Assistant release (if known):**
**Description of problem:** alarm_stream notifications still silent installing latest beta and fresh start. Configuration below:
type: button
tap_action:
confirmation:
text: Find Phone?
action: call-service
service: notify.mobile_app_s21r8
service_data:
title: Finding Phone
message: Ringing phone
ttl: 0
importance: high
priority: high
tag: Find
channel: alarm_stream
icon: 'mdi:cellphone-wireless'
**Traceback (if applicable, to get the logs you may refer to: https://companion.home-assistant.io/docs/troubleshooting/faqs/#android-crash-logs):**
[03-29 15:55:48.322 21235:31640 D/MessagingService]
[03-29 15:55:48.323 21235:31640 D/MessagingService]
Message data payload: {tag=Find, title=Finding Phone, channel=alarm_stream, message=Ringing phone, importance=high}
[03-29 15:55:48.325 1740:4671 D/SamsungAlarmManager]
Cancel Alarm calling from uid:10245 pid :3068 / OP:PendingIntent{d45bbac: PendingIntentRecord{12521f2 com.google.android.gms/com.google.android.gms.gcm broadcastIntent}}
[03-29 15:55:48.325 1740:4671 I/SamsungAlarmManager]
setLocked to kernel - T:2 / 20210329T155852, set=30546841, now=30362501
[03-29 15:55:48.326 1740:4671 I/SamsungAlarmManager]
setLocked to kernel - T:3 / 20210329T155559, set=30373189, now=30362501
[03-29 15:55:48.329 21235:21235 D/MessagingService]
Creating notification with following data: {tag=Find, title=Finding Phone, channel=alarm_stream, message=Ringing phone, importance=high}
[03-29 15:55:48.334 21235:21235 D/RingtoneManager]
getActualDefaultRingtoneUri type :4
[03-29 15:55:48.335 21235:21235 I/RingtoneManager]
Ringtone value : content://media/internal/audio/media/110?title=Homecoming&canonical=1
[03-29 15:55:48.336 21235:21235 D/RingtoneManager]
[03-29 15:55:48.336 21235:21235 I/RingtoneManager]
[03-29 15:55:48.342 4325:4325 D/BoundBrokerSvc]
onBind: Intent { act=com.google.android.gms.measurement.START pkg=com.google.android.gms }
Loading bound service for intent: Intent { act=com.google.android.gms.measurement.START pkg=com.google.android.gms }
[03-29 15:55:48.342 21235:21235 D/MessagingService]
Show notification with tag "Find" and id "2189785"
[03-29 15:55:48.345 1740:2484 D/ApplicationPolicy]
isStatusBarNotificationAllowedAsUser: packageName = io.homeassistant.companion.android,userId = 0
[03-29 15:55:48.345 1740:2484 D/PersonaManagerAdapter]
ContainerOnlyMode - EOS
[03-29 15:55:48.345 1740:1794 D/SettingsProvider]
isChangeAllowed() : name = enabled_notification_listeners
isChangeAllowed() : name = enabled_notification_assistant
isChangeAllowed() : name = enabled_notification_policy_access_packages
[03-29 15:55:48.346 1740:2484 D/ApplicationPolicy]
[03-29 15:55:48.346 1740:2484 D/PersonaManagerAdapter]
[03-29 15:55:48.383 1740:4671 D/SamsungAlarmManager]
Cancel Alarm calling from uid:10245 pid :4325 / OP:PendingIntent{71a70e5: PendingIntentRecord{b070f9c com.google.android.gms/com.google.android.gms.measurement broadcastIntent}}
[03-29 15:55:48.457 2394:2511 D/NetworkController.SecMobileSignalController(0/1)]
onDataActivity: direction=3
[03-29 15:55:48.459 2394:2511 D/MobileSignalIconsSelector]
getDataIconGroup(): connected=true,enabled=true,level=5,inetCondition=1,dataIconGroup=DataIconGroup(5G_TMO),activityIn=true,activityOut=true,lastModified=03-29 15:55:48.458,dataSim=true,networkName=T-Mobile,networkNameData=T-Mobile,dataConnected=true,roaming=false,isDefault=true,isEmergency=false,airplaneMode=false,carrierNetworkChangeMode=false,userSetup=true,defaultDataOff=false,cdmaEriIconIndex=-1,cdmaEriIconMode=-1,callState=0,voWifiConnected=false,shouldShowDisabledDataIcon=false,bluetoothTethered=false,isLTEFemtoCell=false,cardOperator=OTHERS,optionalRadioTech=0,isCAIndicator=false,isLimitedStateForCTCSlaveVoLTE=false,isSWRoaming=false,isMobileDataSettingEnabled=false,nwBoosterRilEnabled=false,nwBoosterSettingEnabled=false,emergencyModeActivated=false,ismmW5G=false, iconSet = null
[03-29 15:55:48.459 2394:2394 D/StatusbarSignalPolicy]
setMobileDataIndicators state = MobileIconState(subId=1, strengthId=2131233570, roaming=false, typeId=2131233374, visible=true, activityId=0, roamingId=0, slotId=0)
[03-29 15:55:48.490 1012:27998 I/sensors-hal]
handle_sns_client_event:182, auto_rotation_event: mode:255, type:1:0/0.010,0.065,9.882
[03-29 15:55:48.517 1028:1120 I/[email protected]]
drmIOCTLLib connectorId: 55
[03-29 15:55:48.518 1028:1120 I/[email protected]]
drmIOCTLLib ret: 0
[03-29 15:55:48.518 886:886 E/audit]
type=1400 audit(1617051348.513:28926): avc: denied { sys_admin } for pid=1028 comm="[email protected]" capability=21 scontext=u:r:vendor_hal_perf_default:s0 tcontext=u:r:vendor_hal_perf_default:s0 tclass=capability permissive=0 SEPF_SM-G991U_11_0007 audit_filtered
drmIOCTLLib close return 0
[03-29 15:55:48.548 1740:1740 I/NotificationService]
RuneStone mIsRuneStoneSupported = true, mIsRuneStoneEnabled = false
[03-29 15:55:48.552 1740:1740 I/AccessibilityManager]
semStartFlashNotification notitype = alarm
[03-29 15:55:48.552 1740:1740 D/AccessibilityManagerService]
[03-29 15:55:48.552 1740:1740 I/AccessibilityManagerService]
semStartFlashNotificationInner() type=Default, pkgName=android, token=android.os.Binder@226e1c6
Can not use light notification
[03-29 15:55:48.555 1740:1740 D/EdgeLightingManager]
isCallingUserSupported : callingUserId=0, mUserId=0, isDualAppId=false, isKnoxId=false
showForNotification : isInteractive=true, isHeadUp=true, color=0, canBypassDnd=false, sbn = StatusBarNotification(pkg=io.homeassistant.companion.android user=UserHandle{0} id=2189785 tag=Find key=0|io.homeassistant.companion.android|2189785|Find|10291: Notification(channel=alarm_stream shortcut=null contentView=null vibrate=null sound=null defaults=0x0 flags=0x10 color=0xff03a9f4 category=alarm vis=PRIVATE semFlags=0x0 semPriority=0 semMissedCount=0))
[03-29 15:55:48.555 1740:1740 D/EdgeLightingClientManager]
isAvailableEdgeLighting: condition=1 mCondition=3 mIsConnected=false0
showForNotificationScreenOn : return false by isAvailableEdgeLighting.
[03-29 15:55:48.567 2736:2736 I/Launcher.NotificationListener]
onNotificationPosted : io.homeassistant.companion.android number : 0
[03-29 15:55:48.567 2736:2852 I/Launcher.NotificationListener]
notificationIsValidForUI : io.homeassistant.companion.android missingTitleAndText : false isGroupHeader : false
[03-29 15:55:48.576 2394:2394 D/InterruptionStateProvider]
No bubble up: not allowed to bubble: 0|io.homeassistant.companion.android|2189785|Find|10291
[03-29 15:55:48.577 2394:2394 W/NotifBindPipeline]
Row is not set so pipeline will not run. notif = 0|io.homeassistant.companion.android|2189785|Find|10291
**Screenshot of problem:**
**Additional information:**
