I have an automation triggered by an event doing AI on video images and then triggers a HTML5 notification. Just to test the new automation editor I have been trying to use it when developing this automation. The problem is that I want to attach an image to the notification and the image file name changes for each trigger. Therefor I am trying to find the image file name through the trigger.event and then feed that result into the url: and image: parts of the data:. When I put this into the message: part it shows up correctly, but not in the data. Does it loose the “variable” when it moves from message: to data:? Is there some way I can do this?
Here is my automation:
- id: '1601385011168'
alias: Person Detected
description: ''
- platform: event
event_type: deepstack.object_detected
condition: []
- service: notify.html5_stians_mobil
title: Person detected!
message: '{% set time = trigger.event.time_fired %}
{% set timestamp_custom = as_timestamp(time) | timestamp_custom("%Y-%m-%d_%H-%M-%S") %}
{% set entity_id = trigger.event.data.entity_id | regex_findall_index("\.(.*)") %}
{% set url = ''/local/snapshots/'' + entity_id + ''_'' + timestamp_custom + ''.jpg'' %}
This works: {{ url }}'
url: '{{ url }}'
image: '{{ url }}'
mode: single
Herer is a screenshot of the same:
The URL shows fine in the message part but not in the url or image parts of the data tag. Do I have to repeat the code for each tag? Does anyone have any tips for meg on this? I have tried to remove the ’ ', replace them with " " etc, but nothing seems to work. For me it looks like it just loose the content of the set variable between the data tags …
