Notify me if someone is home
Hi all,
i wrote an automation if somebody comes home that the light is switching on an a push notification should be send out who is home.
So far the automation works nice but i have the problem with the push-notification:
service: notify.family_push
  message: >-
    {{ 'NameA' if trigger.to_state.entity_id == 'device_tracker.xxxNameA' else
    'NameB' }} is {{ trigger.to_state.state }}
When device_tracker.xxxNameA went home i alway get as pushnofication: NameB is home. So never getting NameA is home
Do you have a hint what i am doing wrong?
post the full automation
alias: When I arrive
description: ''
  - platform: state
    entity_id: group.devices_family
    to: home
condition: []
  - service: notify.family_push
      message: >-
        {{ 'AA' if trigger.to_state.entity_id == 'device_tracker.AA'
        else 'BB' }} is {{ trigger.to_state.state }}
  - condition: numeric_state
    entity_id: sensor.XXXX_average_illumination
    below: '600'
  - scene: scene.abendstimmung
mode: single
It’s the group that’s triggering, not the individual person. If you list everyone separately in the trigger it should work.
thanks for the hint but i still didn´t get it running at all. Do you have a code example?
I tried the following which did also not work
description: ''
  - platform: state
    entity_id:
      - device_tracker.A
      - device_tracker.B
    to: home
condition: []
      message: >-
        {{ 'NameA' if trigger.to_state.entity_id == 'device_tracker.A'
        else 'B' }} is {{ trigger.to_state.state }}
    entity_id: sensor.000000_average_illumination
    below: '600'
mode: single
In what way does it not work?
What does device_tracker.A show under Developer Tools / States?
Does it work if you manually run the automation, bypassing the trigger and conditions?
If the automation is not running at all, did you check that your automation (‘automation.when i arrive’) is on ?
Thanks a lot now it works!.
There is a device_tracker.A2 and device_tracker.A but only A2 is tracked by HA. Why ever there is a A2.
Nevertheless now it works fine.
