Every time i reboot HA, i get the following message in the logs:
Logger: homeassistant.components.mobile_app.notify
Source: components/mobile_app/notify.py:199
integration: Mobile App (documentation, issues)
First occurred: 8:54:41 AM (2 occurrences)
Last logged: 8:54:42 AM
Internal error encountered. This message is generated externally to Home Assistant.
I’ve searched the logs on the app for those timestamps and all i see is (on MacOS):
2024-04-22 08:54:41.612 [Info] [hakit-work-queue] [Environment.swift:71] init() > WebSocket: Received: event: for HARequestIdentifier(rawValue: 19)
2024-04-22 08:54:41.621 [Info] [hakit-work-queue] [Environment.swift:71] init() > WebSocket: Received: event: for HARequestIdentifier(rawValue: 19)
2024-04-22 08:54:41.622 [Info] [hakit-work-queue] [Environment.swift:71] init() > WebSocket: Received: event: for HARequestIdentifier(rawValue: 19)
2024-04-22 08:54:42.066 [Info] [hakit-work-queue] [Environment.swift:71] init() > WebSocket: Received: event: for HARequestIdentifier(rawValue: 19)
2024-04-22 08:54:42.067 [Info] [hakit-work-queue] [Environment.swift:71] init() > WebSocket: Received: event: for HARequestIdentifier(rawValue: 19)
2024-04-22 08:54:43.046 [Info] [hakit-work-queue] [Environment.swift:71] init() > WebSocket: Sending: {"id":40,"support_confirm":true,"type":"mobile_app\/push_notification_channel","webhook_id":"ID_OF_WEBHOOK_REDACTED"}
2024-04-22 08:54:43.180 [Info] [hakit-work-queue] [Environment.swift:71] init() > WebSocket: Received: event: for HARequestIdentifier(rawValue: 19)
2024-04-22 08:54:43.223 [Info] [hakit-work-queue] [Environment.swift:71] init() > WebSocket: Received: result success HARequestIdentifier(rawValue: 40)
2024-04-22 08:54:43.224 [Info] [main] [LocalPushManager.swift:155] handle(initiated:) > started
on the mobile app on IOS the only debug message near that timestamp is a Location Upodate
. I do have a notification that gets sent to my mobile devices whenever HA starts up, but they seem to be working since i am receving the messages. Is there anywhere else I should be looking to troubleshoot these errors?
