[{"id":"e22b9f16.bf003","type":"cronplus","z":"56b1c979.b2c618","name":"10:30 Uhr","outputField":"payload","timeZone":"","options":[{"topic":"Starte Saugvorgang","payload":"","type":"str","expression":"0 30 10 * * *"}],"x":92,"y":464,"wires":[["c835d5d7.5308c8","d69e6228.1f778"]]},{"id":"c835d5d7.5308c8","type":"api-call-service","z":"56b1c979.b2c618","name":"Starte Staubsaugerroboter","version":1,"debugenabled":false,"service_domain":"vacuum","service":"start","entityId":"vacuum.xiaomi_vacuum_cleaner","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":312,"y":464,"wires":[["d141dbd8.c17658"]]},{"id":"7e7e6f15.80cc9","type":"change","z":"56b1c979.b2c618","name":"Nachricht zusammenbauen","rules":[{"t":"set","p":"payload","pt":"msg","to":"Der Staubsauger hat sich vermutlich irgendwo festgefahren","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"Saugvorgang dauert ungewöhnlich lang.","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":792,"y":464,"wires":[["c53c6103.eb16e","c168df3c.7aa1c"]]},{"id":"858cb5dd.31b298","type":"change","z":"56b1c979.b2c618","name":"Nachricht zusammenbauen","rules":[{"t":"set","p":"payload","pt":"msg","to":"Der Staubsauger ist wieder gedockt.","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"Saugvorgang beendet.","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":792,"y":512,"wires":[["c168df3c.7aa1c","c53c6103.eb16e"]]},{"id":"c168df3c.7aa1c","type":"api-call-service","z":"56b1c979.b2c618","name":"Telegram an Frauke","version":1,"debugenabled":false,"service_domain":"notify","service":"telegram_frauke","entityId":"","data":"{\"title\":\"{{ topic }}\",\"message\":\"{{ payload }}\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1060,"y":464,"wires":[[]]},{"id":"c53c6103.eb16e","type":"api-call-service","z":"56b1c979.b2c618","name":"Telegram an Simon","version":1,"debugenabled":false,"service_domain":"notify","service":"telegram_simon","entityId":"","data":"{\"title\":\"{{ topic }}\",\"message\":\"{{ payload }}\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1050,"y":512,"wires":[[]]},{"id":"d141dbd8.c17658","type":"ha-wait-until","z":"56b1c979.b2c618","name":"wait until docked?","outputs":2,"entityId":"vacuum.xiaomi_vacuum_cleaner","entityIdFilterType":"exact","property":"state","comparator":"is","value":"docked","valueType":"str","timeout":"50","timeoutType":"num","timeoutUnits":"minutes","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":538,"y":464,"wires":[[],["7e7e6f15.80cc9","1a839b27.1cb245"]]},{"id":"49cfb758.fb9508","type":"trigger-state","z":"56b1c979.b2c618","name":"Vacuum","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"vacuum.xiaomi_vacuum_cleaner","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"id":"o01ny7bj64","targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"includes","comparatorValueDatatype":"list","comparatorValue":"returning,docked"}],"constraintsmustmatch":"all","outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":412,"y":512,"wires":[["858cb5dd.31b298","d69e6228.1f778"],[]]},{"id":"d69e6228.1f778","type":"change","z":"56b1c979.b2c618","name":"disable","rules":[{"t":"set","p":"disable","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":252,"y":512,"wires":[["49cfb758.fb9508"]]},{"id":"1a839b27.1cb245","type":"change","z":"56b1c979.b2c618","name":"enable","rules":[{"t":"set","p":"enable","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":578,"y":560,"wires":[["49cfb758.fb9508"]]}]
You could also add two additional constraints to the trigger-state node “Vacuum” that would check if someone is not home and not send the notification which the assumption if someone is home then they were the one who probably returned the vacuum to the base station.
edit:
different version
[{"id":"2da9bcf7.cdb654","type":"cronplus","z":"56b1c979.b2c618","name":"10:30 Uhr","outputField":"payload","timeZone":"","options":[{"topic":"Starte Saugvorgang","payload":"","type":"str","expression":"0 30 10 * * *"}],"x":92,"y":640,"wires":[["5efd07ca.73a268"]]},{"id":"5efd07ca.73a268","type":"api-call-service","z":"56b1c979.b2c618","name":"Starte Staubsaugerroboter","version":1,"debugenabled":false,"service_domain":"vacuum","service":"start","entityId":"vacuum.xiaomi_vacuum_cleaner","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":312,"y":640,"wires":[["ee4b3554.7efff8"]]},{"id":"cd4f3d7c.6a30b","type":"change","z":"56b1c979.b2c618","name":"Nachricht zusammenbauen","rules":[{"t":"set","p":"payload","pt":"msg","to":"Der Staubsauger hat sich vermutlich irgendwo festgefahren","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"Saugvorgang dauert ungewöhnlich lang.","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":792,"y":640,"wires":[["a3ff1cf9.1fddd","e782ae25.bc32a"]]},{"id":"381c3358.2463dc","type":"change","z":"56b1c979.b2c618","name":"Nachricht zusammenbauen","rules":[{"t":"set","p":"payload","pt":"msg","to":"Der Staubsauger ist wieder gedockt.","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"Saugvorgang beendet.","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":792,"y":688,"wires":[["e782ae25.bc32a","a3ff1cf9.1fddd"]]},{"id":"e782ae25.bc32a","type":"api-call-service","z":"56b1c979.b2c618","name":"Telegram an Frauke","version":1,"debugenabled":false,"service_domain":"notify","service":"telegram_frauke","entityId":"","data":"{\"title\":\"{{ topic }}\",\"message\":\"{{ payload }}\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1060,"y":640,"wires":[[]]},{"id":"a3ff1cf9.1fddd","type":"api-call-service","z":"56b1c979.b2c618","name":"Telegram an Simon","version":1,"debugenabled":false,"service_domain":"notify","service":"telegram_simon","entityId":"","data":"{\"title\":\"{{ topic }}\",\"message\":\"{{ payload }}\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1050,"y":688,"wires":[[]]},{"id":"ee4b3554.7efff8","type":"ha-wait-until","z":"56b1c979.b2c618","name":"wait until docked?","outputs":2,"entityId":"vacuum.xiaomi_vacuum_cleaner","entityIdFilterType":"exact","property":"state","comparator":"is","value":"docked","valueType":"str","timeout":"50","timeoutType":"num","timeoutUnits":"minutes","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":538,"y":640,"wires":[[],["cd4f3d7c.6a30b","355224f9.7aeabc"]]},{"id":"355224f9.7aeabc","type":"ha-wait-until","z":"56b1c979.b2c618","name":"wait until docked?","outputs":1,"entityId":"vacuum.xiaomi_vacuum_cleaner","entityIdFilterType":"exact","property":"state","comparator":"includes","value":"returning,docked","valueType":"str","timeout":"0","timeoutType":"num","timeoutUnits":"minutes","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":282,"y":688,"wires":[["5dd8242a.67e36c"]]},{"id":"5dd8242a.67e36c","type":"api-current-state","z":"56b1c979.b2c618","name":"nobody home?","version":1,"outputs":2,"halt_if":"$entity().state != \"not_home\" and $entities(\"person.frauke\").state != \"not_home\"","halt_if_type":"jsonata","halt_if_compare":"jsonata","override_topic":false,"entity_id":"person.simon","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":528,"y":688,"wires":[["381c3358.2463dc"],[]]}]
