Hello
I have activate MFA with TOTP and I also want to add “Notify One-Time Password” but that’s not shown in my profile under the Multi-factor Authentication Modules as described in the official documentation: Multi-factor authentication - Home Assistant
The Notify One-Time Password was not shown even before activating TOTP. I tried disabling TOTP, removing .storage/auth_module.totp, manually creating an auth_modules.notify in .storage/ with similar but adjusted content from totp module, but still no luck. I have restarted my HA after each and every little change.
In configuration.yaml I have
homeassistant:
customize: !include customize.yaml
auth_mfa_modules:
- type: notify
- type: totp
auth_providers:
- type: trusted_networks
trusted_networks:
- !secret my_home_net
trusted_users:
- !secret my_home_net: !secret my_user
allow_bypass_login: true
- type: homeassistant
frontend:
themes: !include_dir_merge_named themes
I am using:
Home Assistant 2022.11.4
Frontend 20221108.0 - latest
Is there a known bug about this issue, or am I missing something?
