Notify retrigger delay issue
I have set up an automation to send an alert when the solar PV batteries start discharging above 1kW. This is so I can work out what is drawing the power and stop it if required. I have added a delay as the power use may initially be high but then go down and back up over the threshold and I don’t want it to trigger the alert every time for this one device. This is what I have currently but I still get constant triggers each time the power goes over the threshold:
alias: Battery discharge over 1kW
description: Battery discharge > 1kW
  - platform: numeric_state
    entity_id: sensor.battery_discharge
    above: 1
condition:
  - condition: time
    after: "05:29:00"
    before: "23:31:00"
    weekday:
      - mon
      - tue
      - wed
      - thu
      - fri
      - sat
      - sun
  - service: notify.all_phones
      message: Battery is discharging >1kW
  - wait_for_trigger:
        below: "0.5"
    timeout:
      hours: 0
      minutes: 10
      seconds: 0
      milliseconds: 0
    continue_on_timeout: false
mode: single
