I recently transitioned from hassbian
to hass.io
and so far have just about everything transitioned including smartthings and many others. But for the life of me I cannot get notifications working and I’ve now tried multiple platforms. I was previously using sendgrid
and slack
. But neither service has been working with hass.io
. I even tried setting up HTML5
to see if that might work but also no joy.
I’ve noticed a few odd errors such as I cannot get my Nest thermostat to complete the callback after successfully getting a code. As well as speedtest unable to get a connection. For the life of me I’m not sure what’s going on with these outbound service calls. I’m assuming there is no iptables or other local firewall setting that I may have inadvertently setup while getting everything online?
Below is the notification I receive when attempting to test HTML5
notifications. I’m happy to share any other notifications as well if it might help.
Log Details (ERROR)
Sat Dec 16 2017 18:56:45 GMT-0800 (Pacific Standard Time)
Error doing job: Task exception was never retrieved
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 60, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/lib/python3.6/socket.py", line 743, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 346, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 850, in _validate_conn
conn.connect()
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 284, in connect
conn = self._new_conn()
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 150, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x71571a90>: Failed to establish a new connection: [Errno -3] Try again
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='android.googleapis.com', port=443): Max retries exceeded with url: /gcm/send (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x71571a90>: Failed to establish a new connection: [Errno -3] Try again',))
File "/usr/lib/python3.6/asyncio/tasks.py", line 181, in _step
result = coro.throw(exc)
File "/usr/lib/python3.6/site-packages/homeassistant/core.py", line 1031, in _event_to_service_call
yield from service_handler.func(service_call)
File "/usr/lib/python3.6/site-packages/homeassistant/components/notify/__init__.py", line 143, in async_notify_message
yield from notify_service.async_send_message(**kwargs)
File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/notify/html5.py", line 387, in send_message
json.dumps(payload), gcm_key=self._gcm_key, ttl='86400')
File "/usr/lib/python3.6/site-packages/pywebpush/__init__.py", line 291, in send
timeout=timeout)
File "/usr/lib/python3.6/site-packages/requests/api.py", line 112, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 508, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='android.googleapis.com', port=443): Max retries exceeded with url: /gcm/send (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x71571a90>: Failed to establish a new connection: [Errno -3] Try again',))
Even Darksky weather is failing to connect.
Log Details (ERROR)
Sat Dec 16 2017 18:55:22 GMT-0800 (Pacific Standard Time)
Unable to connect to Dark Sky. HTTPSConnectionPool(host='api.darksky.net', port=443): Max retries exceeded with url: /forecast/darky_api_key/34.618625,-118.215772?units=us (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x74078910>: Failed to establish a new connection: [Errno -3] Try again',))
