test_telegram:
alias: test_telegram
sequence:
- service: notify_telegram
title: Test Message
message: 'This is a test!'
I have also tried adding “” for the message and get same error.
I have also validated above with online YAML validator.
Logs:
WARNING (MainThread) [homeassistant.core] Unable to find service notify/telegram
Edit: forgot to mention I am on Hassio installation.
Thanks for your quick reply @keithh666. After posting this thread, I tried using the hassio inbuild script option and it spit out below configuration.
'1513307752282':
alias: Telegram
sequence:
- data:
message: This is a test!
title: New message
service: notify.telegram
Even after that, it gives me same error as shown below.
2017-12-15 14:16:09 WARNING (MainThread) [homeassistant.core] Unable to find service notify/telegram
2017-12-15 14:16:22 WARNING (MainThread) [homeassistant.core] Unable to find service notify/telegram
Thanks,
RT
OK, that looks ok now, did you restart HA? After each config change you have to restart HA. However always do a config check before restarting - not so relevant for normal HA but is very relevant for Hass.io
