I need to create an automation which notifies me when a sensor has not been updated in X amount of minutes but not sure how to formulate the automation, i.e. what trigger to use
I assume it is the state trigger but how to set it up?
If your sensor times out and goes unavailable, you can use something like this:
- alias: lux_out_of_service
initial_state: true
platform: state
entity_id: sensor.front_verandah_lux
to: unavailable
for: 00:45:00
service: persistent_notification.create
data_template:
message: Front verandah lux sensor battery flat?
Te lux sensor has an expire_after
value to make it go unavailable:
- platform: mqtt
name: "Front Verandah Lux"
state_topic: "lux_sensor/sensor/bh1750_illuminance/state"
device_class: illuminance
unit_of_measurement: "lx"
expire_after: 900
BTW if it’s not a MQTT sensor, or doesn’t go unavailable when not updated - you can do a trigger when the state doesn’t change in x amount of time:
- platform: state
for: "00:45:00"
Yoo can use a template for e.g. last_updated or last_changed, depends on what you are looking for
{{ ((as_timestamp(now()) - as_timestamp(states.YOURSENSOR.last_changed)) / 60) | int }}
Yes I think this is the one as it’s value remains the same and won’t go to unavailable
Depends if it is just the state that you are looking at
I tried the template but it doesn’t work for me as the value for {{states.solar_battery_power.last_changed}}
is equal to None when it obviously should be 4 mins:
It should be
{{ states.sensor.solar_battery_power.last_changed }}
Yes that was it, missing the sensor part
Basically, you want a “stale sensor” detector. I provided an example here:
