surge919
(surge919)
1
Has anyone created an automation to notify when an unknown devices connects to their network?
I have another similar post but if that can’t be done in the current version, notification when unknown devices appear would be helpful…
this is my other thread… https://community.home-assistant.io/t/can-i-show-unknown-devices-in-default-view/
thx
Did you ever find an answer to this?
PeWu
3
Any update on this? I was looking for the same functionality.
Is there a feature request?
PeWu
4
I managed to implement this using AppDaemon. The script checks if the device name is a 12-hex string.
import appdaemon.appapi as appapi
import re
class DeviceNotify(appapi.AppDaemon):
def initialize(self):
self.listen_state(self.newDevice, "device_tracker", new = "home")
def newDevice(self, entity, attribute, old, new, kwargs):
device_name = self.split_entity(entity)[1]
if re.match("[a-f0-9]{12}$", device_name):
message = "Unknown device connected: {}".format(device_name)
self.notify(message)
I did it as a normal notification in yaml.
See at the bottom of this file:
I also copied it from a post on this forum somewhere.
edit: replaced link with permalink and high-lighting
