Notify when value goes above/below certain values
I’d like to have an automations that triggers when a value goes above a certain value.
Of course this would be an easy task, but the thing is I’d like to get notified when the value goes above (lets say) 50%, 60%, 70% AND
Below 20% and 10%.
This is my example:
- alias: Percentage Alert
  initial_state: 'on'
    - platform: numeric_state
      entity_id: sensor.percentage_value
      below: 20
      for: '00:10:00'
      below: 10
      for: '00:10:00'
      above: 50
      for: '00:10:00'
      above: 60
      for: '00:10:00'
      above: 70
      for: '00:10:00'
    - service: notify.iosdevice
        message: "Curent value: {{ states.sensor.percentage_value.state }} "
The issue with this automation is that 10 min after a restart of ha I will get some notifications, because some triggers are true.
Lets say the percentage value is 55% at the restart. This would cause two notifications, but I only want this to happen when the value rises aboce or falls below the certain values.
Any help is appreciated, maybe you have a nice idea again @petro
I’d just add a condition that the automation doesn’t trigger if HA started less than 11 min ago:
here is an example of one of my alerts:
  sensors:
    alert_aloe_vera_humidity_too_low:
      entity_id: sensor.aloe_vera_moisture
      value_template: >-
        {% if (((states("sensor.aloe_vera_moisture") )| default(100)) | int < 10) and (states("sensor.uptime") | float > 0.1)%}on{% else %}off{%endif%}
      friendly_name: Aloe Vera Humidity below 15%
the key here is the and (states("sensor.uptime") | float > 0.1)
my sensor.uptime gives me the number of hours since HA started:
- platform: uptime
  unit_of_measurement: hours
@lolouk44 thanks for your advice.
I added this to my automation:
  condition:
    - condition: numeric_state
      entity_id: sensor.uptime
      above: 0.2
