As the title explains, I am trying to create an automation to turn a Frigate camera on/off.
Frigate release notes suggest that this should be possible:
Dynamically Enable and Disable Cameras
Frigate now offers the ability to enable / disable cameras dynamically, including buttons in the UI, MQTT, and using the
camera.turn_on/camera.turn_offservices in the Home Assistant Integration. Disabling a camera stops all of Frigate’s decoding and processing for that camera. See the documentation.
A simplified version of my configuration is:
alias: Toggle Camera Test
description: ''
triggers:
- trigger: state
entity_id:
- input_boolean.toggle_cam
conditions: []
actions:
- action: notify.mobile_app_me
metadata: {}
message: Camera is {{ trigger.to_state.state }}
- if:
- condition: template
value_template: '{{ trigger.to_state.state == "on" }}'
then:
- action: camera.turn_on
metadata: {}
data: {}
entity_id: camera.camera_1
else:
- action: camera.turn_off
metadata: {}
data: {}
mode: single
I receive the configured notification, however, When it comes to the camera control, I get the error:
Logger: homeassistant.components.automation.toggle_cam
Source: components/automation/__init__.py:717
integration: Automation (documentation, issues)
While executing automation automation.toggle_cam
Full Error
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 717, in async_trigger
return await self.action_script.async_run(
variables, trigger_context, started_action
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1836, in async_run
return await asyncio.shield(create_eager_task(run.async_run()))
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 460, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 526, in _async_step
self._handle_exception(
ex, continue_on_error, self._log_exceptions or log_exceptions
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 556, in _handle_exception
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 524, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 719, in _async_step_choose
await self._async_run_script(script)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 636, in _async_run_script
result = await self._async_run_long_action(
...<6 lines>...
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 624, in _async_run_long_action
return await long_task
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1012, in _async_step_call_service
response_data = await self._async_run_long_action(
...<9 lines>...
File "/usr/src/homeassistant/homeassistant/core.py", line 2835, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2878, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 877, in entity_service_call
raise result from None
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1624, in async_request_call
return await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 924, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 646, in async_turn_off
await self.hass.async_add_executor_job(self.turn_off)
File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 642, in turn_off
raise NotImplementedError
NotImplementedError
- Does this error make sense? I am not familiar with Python by reading the docs suggests that this due to a class not properly extending a base class (???)
- Has anyone been able to get this feature working?
- Can anyone clarify whether the horse that I am flogging is dead or alive?
